Latest Update.
The lower GI was finally fixed after clearing up shorts that I installed and replacing the fuse.
The lights on the door were due to a broken power wire on the connector at the door. In fact there were two broken wires, one on the male side, one on the female side.
I purchased some 0.093 male and female pins. I also purchased the extraction tool (which for this connector was a waste of money as there is no way to insert it. I tried using the extraction tool on the male side, it just broke the pin, but wouldn't / couldn't insert to where the barb was. I ended up breaking off the pin from the front side and using a nail and some brute force to get it out.
On the female side, again, the tool wasn't going to insert into this plug, so I grabbed a small drill bit and very slowly used the drill to get the pin out. Not sure if someone has a better way, but given that I was only removing those two, it got the job done.
The wires that I fixed were the yellow (GI power wire) and the Green with Brown stripe wire for the switch matrix, (Column 1).
ChrisHibler With that green wire fixed, the machine started acting wonky. As a reminder I have a variety of battery acid issues on the main board, so I'm not sure if that has anything to do with it. I have a new one on order from DumbAss but I want to get as much fixed / working as possible prior to getting the new board.
Prior to fixing that pin on the connector, I was able to load the factory settings and get into diagnostics mode. (None of the column one switches seemed to work, and they still don't). Even though I was able to previously get into self test, I am unable to use the credit button for anything either in the game adjustments (which I can get into) or the self test (when it used to work).
Neither of the coin slots work (using the switch), tilt, etc.
A couple of questions:
Is there a way to test the connectors / pins from either the interconnect board or the CPU to see if the issue is starting there?
Am I at a point that I just need to wait for the new CPU board and go from there?
While the picture doesn't show it from the refresh rate, the display is working fine and complete. The pictures included show the power on message, Factory Settings, then if I click the advance button (test switch) it shows Earthshaker and I'm assuming the ROM version. If I load the factory settings in an effort to get into the self test mode, the screen fills with the pattern in the 3rd picture. (Again not showing all due to refresh rate and camera).
I also notice that the "blanking" led is lit on the main board (not sure what that is).
Any thoughts / suggestions on what I should do / work on while waiting for the new board?
Does it make sense that having that green-brown wire broken at the door would cause the CPU to no longer go into test mode?
Also, while the wire was broken, The test / manual up / auto down switches were working, which doesn't make too much sense to me either.
I've also included the switch matrix and other related information in the final (pdf) attachment, but you need to click on it to see the matrix (Page 2) and wiring colors.
Thanks for your help.
PXL_20220612_184648983 (resized).jpgPXL_20220612_184723512 (resized).jpgPXL_20220612_184746094 (resized).jpgPXL_20220612_184753523 (resized).jpgswith matrix info.pdf
