(Topic ID: 242517)
Earthshaker pics PLEASE
By zr11990
  • 14 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by zr11990
    #1 4 years ago
    I need to see pics of the top and underneath of the Nevada/California mechanism. I need to see how the two wireforms attach to it and the screws that are used. Someone had taken mine apart and used the wrong stuff and I don't know what Im supposed to use. Thanks in advance.
    #2 4 years ago
    I have an album here that may be of help.... Tons of pics and resources from when I refurbed one many years ago....
    https://1drv.ms/f/s!Akk53b-cuRJ0iSgdsI49HnH9hJNz
    #3 4 years ago
    I think you sent me those pics already. What I really need to see is underneath.
    #4 4 years ago
    Do you still need pictures?
    #5 4 years ago
    Here's a couple pix from my recent rebuild. The first is prior to installing splitting california. Two pan head screws hold the back part of splitting cali with one of those on the wire ramp. The forward screw is countersunk so it's flush with splitting cali and it goes through the plastic, through the end of the wire ramp and into the tall threaded post. It's pretty blind putting this thing on while getting the moving part of the mech into the slot on the bottom side of splitting cali, so tricky.
    I may have other pix if these aren't good enough.
    IMG_0177 (resized).jpegIMG_0177 (resized).jpegIMG_0180 (resized).jpegIMG_0180 (resized).jpeg
    #6 4 years ago
    Here you go
    #7 4 years ago
    Another angle.
    IMG_0101 (resized).JPGIMG_0101 (resized).JPGIMG_0101 (resized).JPGIMG_0101 (resized).JPG
    #8 4 years ago
    Actually I wanted to see the underneath of the Nevada/California apparatus. I want to see what kind of nut goes onto the screws.
    thank you for the pics.
    #9 4 years ago
    Quoted from zr11990:
    That is the Nevada/California mech.
    #10 4 years ago
    mines stripped apart so can take pictures of the underneath the mech with screws/bolts later if you still need this
    #11 4 years ago
    #12 4 years ago
    hmm I'm in same boat. I am unsure where the screws go DOH only got one bolt in my fault line bag not sure which hole it goes into.
    #13 4 years ago
    The just went to the hardware store and bought a Phillips head machine screw that’s fit the nylock nut and it worked fine.
    #14 4 years ago
    I finally figured out what I needed to know the hard way the screw goes directly into the post that holds the ramp down. There is no nut on the back. Thanks for playing though.
    This page was printed from https://pinside.com/pinball/forum/topic/earthshaker-pics-please and we tried optimising it for printing. Some page elements may have been deliberately hidden.
