New! Dark mode!
(Topic ID: 90961)
earthshaker help
By freezie
6 years ago
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by freezie
#1 6 years ago
strange problem , during multiball my earthshaker will not quit , it just simply restarts, music changes , shaker quits , score resets to 0 and the game just carrys on like nothing changed. doesnt matter if i have drained a ball or have all three out there. i went through and tested all switches and couldnt find any issues. any ideas would be greatly appreciated !
#2 6 years ago
Possibly a switch matrix issue with the start button? Multiball might be getting enough other switch hits to get the combination that fires the credit button.
#3 6 years ago
i was thinking the same thing , but when it does it while on ball one , it doesnt add a second player , it just resets in the blink of an eye to zero and the sounds change .
#4 6 years ago
Quoted from freezie:
Damn then. I haven't run into that kind of reset yet, good luck and I'll be following.
#5 6 years ago
When I figure it out , I will post what it was , can always help someone down the road .
#6 6 years ago
Bump for the day crew !
#7 6 years ago
Check all the connectors. Look for tarnished pins on the boards. Reseat everything. If it is doing it while it is shaking it could be a loose connection. It could also be low voltage on the power supply. I had a similar flakey issue that eventually got worse as the power board got weaker and was easier to identify.
#8 6 years ago
Good points , I did check some cables . But not all I will admit , and I'm suspicious that it's possible power supply related . I will get some time this weekend to dig in . All good suggestions so far . Thanks guys .
#9 6 years ago
Very weird , can't replicate it , but I did find yesterday , after changing every diode in the switch matrix ( sure I got them all) during multiball , at one point, left and right outlines would add a credit. I haven't been able to replicate it again .
#10 6 years ago
Played over a dozen games today , no problem . Had to have been a diode , weird I couldn't actually confirm and find it.
#11 6 years ago
I would check your voltage and see how close to 4.9 it is. That is where mine started flaking out. Not quite enough for the watchdog circuit to trip.
#12 6 years ago
I have a steady 5.1 on the power supply and a steady 4.98 on the CPU board . Definately was a switch issue . Just tough to find.
#13 6 years ago
If you swapped all the diodes, presumably you made sure no metal switch tabs were too close to any other metal object? If so, you may need to look for pinched wires somewhere that may be causing the short instead.
#14 6 years ago
seems fine now that i changed all diodes.
$ 279.95
Pin Stadium Pinball Mods
$ 54.99
$ 259.95
3,950 (OBO)
Plymouth, MN
$ 39.99
2,800 (OBO)
Oviedo, FL
$ 54.99
3,100 (Firm)
Gresham, OR
$ 54.99
