(Topic ID: 119916)
Earthshaker Blowing F3 Fuse Backboard/Upper PF GI Out
By hkamania
9 years ago
  • 32 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by DocRotCod
#1 9 years ago
Hello,
I have an Earthshaker and the F3 fuse on is blown, my upper playfield and backboard GI are out. I replaced the fuse and it blows out right away. If I remove the connectors to the back board relay and the upper play field relay, the fuse does NOT blow. Has anyone had an issue like this? I am not sure why the fuse is blowing out and I cant see any obvious shorts etc.
thanks and hope all is well
tony
#2 9 years ago
Check those relay boards for any burnt connectors. Likely you will find some pins that will need to be replaced, possibly even have to fix burnt traces on a relay board as well.
#3 9 years ago
Quoted from hkamania:
Hello,
tony
Check the connectors, then start looking for shorts on those gi strands.
#4 9 years ago
Hello,
Thanks guys,I am working on this now. I checked the relay boards just now PinballManiac40 they are silver and no burning etc, thanks for the suggestion. Dsuperbee, thanks I am checking the strands now. Thanks for the quick reply, I am really stuck on this.
Tony
#5 9 years ago
Have you done anything or changed anything recently on the game or did this just happen out of nowhere?
#6 9 years ago
Also the bottom board in the backbox is the interconnect board. To the far right is a connector with 4 yellow wires going into the connector. Pull that connector out and check for burnt pins there.
Also you would need to pull the 4 fuses off that interconnect board and test them to make sure they are good. These cannot be checked while connected in the board.
#7 9 years ago
DocRotCod, thanks for the reply. it happended out of nowhere, I had it for about a year and i noticed while playing.
PinballManiac40 the header is a little brown but its not burnt up, I checked continuity on them and they test ok.
#8 9 years ago
Let me look in the manual i'll report back in a few minutes.
#9 9 years ago
If the header is already brown, you need to replace it and the header pins.
#10 9 years ago
Check the transistor at q9 and q16. These are for upper gi relay and backbox relay.
Download the manual from ipdb.org and look at page 2. The upper playfield and backbox gi are on the same connector.
#11 9 years ago
Quoted from dsuperbee:
rgr, I'll have to order some, can you please suggest a good place and the type of connector to order? The headers are intact 100% not nearly burnt up, is it the resistance on the connector thats prob blowing the fuse out? I just started working on pins, I just did this exact same thing on an atari apb arcade machine , but on that board the pins were burnt so bad the case was melted and most of the wires were already broken so it was obvious.
thanks for all you help on this so far,
Tony
#12 9 years ago
Quoted from DocRotCod:
thank you sir! will do, I am heading over with my meter now.
Thanks again for all your help on this, its driving me crazy,
Tony
#13 9 years ago
Tony
I just checked and they test good, I used the meter on beep test and used the strap to test the transistors, they both are ok.
thanks for looking that up!
Tony
#14 9 years ago
Tony
#15 9 years ago
Tony
If the header is brown indicating heat (and therefore resistance), odds are the male pins have had their playing worn/burned off. Replace both. I get my stuff via mouser, but Great Plains electronics is great as well, and a bit more user friendly.
https://www.greatplainselectronics.com/categories.asp?cat=37
#16 9 years ago
Disconnect the relay on either the upper gi or the backbox and see if you can further narrow it down as to which one is blowing the fuse. If either blows the fuse, I suspect a short. If one or the other blows the fuse we can go from there.
#17 9 years ago
nice! so with back box relay connected no fuse blow! infact the back is now lit again!! upper playfield relay is still disconnected.
Tony
#18 9 years ago
Check on the playfield GI sockets and make sure there are not any wires touching. Have you LED'd this pin? I have seen shorted LED's do this. Also, start removing groups of 10 bulbs and see if you can narrow down where the segment is and you can start to isolate where the short may be.
I know the bulbs are not easy to get to on this pin, especially the GI. so I would start with just a real thorough visual inspection.
#19 9 years ago
Will do, I am looking now. No, I haven't dont the LED yet but I want to thanks for the heads up on that. I was looking all day and nothing seems out of the ordinary. Is it possible the relay board is bad? I am going bk to the machine now to check the GI sockets and to remove the bulbs like you suggested.
Thank you sir!
Tony
#20 9 years ago
It's possible. Let me look at something in the manual real quick.
#21 9 years ago
http://www.marcospec.com/control/keywordsearch;jsessionid=D74528DF35ED5511C1B81D2B49A1695E.jvm1?SEARCH_STRING=c-11902-1
Looks like this is the replacement relay board from Marco. $20 not too bad. Not saying that is the fix, but in case we need it you have a link.
#22 9 years ago
awesome! thanks a lot! ill order that as a spare and to test, I am checking those upper GI's now like you said. Thanks for looking that up! I'll post asap if i find something on the upper GI sockets
Tony
#23 9 years ago
You can swap the two relay boards to see if it follows the board.
Normally you can see on the back of the relay board some damage.
#24 9 years ago
Quoted from PinballManiac40:
Will do, thank you sir. I am going bk at earthaker now.
Tony
#25 9 years ago
I just wanted to send an update PinballManiac40, I swapped the relay with the good one from the lower play field and the fuse went right out. I am still going over the upper GI traces and so far nothing seems obvious. I am going to change out the connector and go over it again. Do you have any suggestions on how to narrow down the short?
Thanks again, and thanks everyone for your help on this,
Tony Moger
#26 9 years ago
Great. So at least you know right now you do not need a relay board. Was the wiring that went to the relay board brown or burnt? You still need to change the wired connector on the far right connector, J6, on the interconnect board.
Personally, I would remove the interconnect board and inspect the bottom side of the board. If you do remove it can you post pictures of it as well? Note any other wired connectors on the bottom right portion of the interconnect board as you remove them, especially J7, J8, and J9.
In the past, I had a Dr. Dude and a Black Knight 2000 interconnect board that had an internal short in the board. I ended up buying another board out of a similar machine and reconfigured it to each game as needed.
#27 9 years ago
Here is a picture of the one of out my Dr. Dude. It kept blowing out a fuse. I determinted there was a high resistance short between two pins, which is really no way to fix other that cut traces and route them externally off the board to bypass the damaged area within the board. Just seemed more reliable to replace it. There was only slight discoloration of the board at J6 that I could see which is why I had pulled it out to inspect further.
The one out of my Black Knight 2000 was way worse that this one.Dr Dude interconnect board.JPGDr Dude interconnect board.JPG
#28 9 years ago
Hello,
I just got my connectors and header pins to replace, I removed the inter connect board PinballManiac40 and took a pic, the pin is a bit burnt, also the old owner moved the wire one to the left on J9 because it was totally gone, I just realized when I removed it. I am changing the connector and header today.
Hope all is well,
Tony
#29 9 years ago
Thank you all! My earhshaker is back to 100%! Upper GI and backback are lit and functioning properly! PinballManiac40 , Dotrotcod and dsuperbee your the best! I replaced the header on J9 and the J9 Connector as well, I had to fix a trace also, and move a cable that the original owner hacked. I attached a pic of the jumper I added.
Thanks again! and please let me know if i can ever help with anything,
Tony
#30 9 years ago
The one out of my Black Knight 2000 was way worse that this one.Dr Dude interconnect board.JPG (Click image to enlarge)
Tony
#31 9 years ago
Great. Enjoy your game. Please mark this thread as resolved at the top of the page.
#32 9 years ago
Glad you got it going! Good detective work.
$ 44.99
Pinball Shark
$ 12.00
System-J
Gweem's Mods
$ 50.00
RRB Crafts
$ 19.99
$ 3.00
Tools
Nezzy's Pinball Prints
Fort Lauderdale, FL
$ 36.95
3,300 (OBO)
Shepherdsville, KY
$ 18.95
$ 1.29
Daddio's 3D Printed Mods
$ 27.00
3,000
Fort Wayne, IN
$ 39.99
This page was printed from https://pinside.com/pinball/forum/topic/earthshaker-blowing-f3-fuse-backboardupper-pf-gi-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
