so I recently got my high speed up after a full tear down. Despite my attention to watching the coil power/diode connection, I managed to still hook one up backward, and blowing a tip122(and f2). I replaced it and while doing so checked out all the drive transistors both pre drive and power for the solenoid drives. When i got to Q32 it seemed a bit off and I replaced it, while doing so I checked the predriver-Q28 which was giving me a DMM reading of ~232 both ways...figuring it was shot I removed it. When I bench tested it it seemed fine giving me a ~443 and blocking it in reverse? since I had not tested the coil yet (eject hole) I reinstalled everything and regained all but this coil (of course). So I removed the board and still have the same readings...so now I'm thinking I may have done some damage to the resistor networks, but before I start getting into that... I'd figure I pick some brains here as to what may be causing this anomaly. I wish I had just replaced the pre-drive as I had it out....but it seems fine? Thanks gents
