(Topic ID: 174164)
Early Bally SS MPU 3 Flashes
By Validpowerdetect
7 years ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by slghokie
#1 7 years ago
Mpu worked for years ib Star Trek. Gets 3 flashes.
Changed U10, U9, And U17. No go.
Looking at R/W with a scope, it's there thru 3flashes, then goes away.
This happens if U10 is in the socket or not.
Not sure if any of this is germane to the problem or not.
#2 7 years ago
Swap U10 and U11
#3 7 years ago
Occasionally a bad U8 RAM or a U11 PIA will make the POST fail.
Make sure the IRQ, reset, clock phase 2 all make it to the pia. Make sure U17 gate for chip select 2 is pulsing when the PIA is being tested. U18 is also involved in the CS2 circuit (U18 makes /A9 and /A12 which then NAND at U17).
#4 7 years ago
Will do these tests Fri and report back. Thanks!
#5 7 years ago
IRQ, VUA2, Rst all good at U10.
CS2 pulses, as does R/W thru the first few flashes, then both
go away when U10 is being tested.
Replaced U17,18,7,8,10,11 with same results.
#6 7 years ago
Quoted from Validpowerdetect:
have to assume a soldering mistake, broken via, bad IC socket at this point...
I guess you could whack IC14(zero cross) and anything else related to its CS circuitry.
#7 7 years ago
It's got me frustrated for sure. Working one minute, tits up the next. Sockets fot the pias are my next move.
#8 7 years ago
Did some more investigation on this.
Without a chip in U7, R/W, C/S signals all stay up.
When a chip is in U7, they die after the third flash.
Interesting.
#9 7 years ago
Its hard to say what the software program wants to do once a failed test happens. Results likely to be different when a RAM test fails or PIA test fails. I imagine that software ends up in some infinite loop.
Trace every circuit out including like the output disables for the RAM. Say the OD is stuck on the U8 ram and it craps on the data bus when the PIA is being tested. Stuff like that. Trace the VUA-2 circuit too. Zero cross, display interrupt etc.
Solder splash? Get a bright light and look over the board really really well. A good visual inspection goes a long way.
#10 7 years ago
Quoted from barakandl:
.... test fails. I imagine that software ends up in some infinite loop.
Correct, once a failure is detected in the power on tests, the software sits in an endless loop on an instruction that branches to itself. So you won't get any more activity on the R/W line and the CS signals to the PIAs will probably cease.
All the PIA test at 4 and 5 does is check the internal registers of the PIA. It doesn't test the I/O pins because there's no external feedback mechanism.
So if you look at the schematics, the signals on the left side of the PIA chips are important for test 4 & 5, the right side signals not.
#11 7 years ago
another thought...
shorted cap on a pia output. Use Leon's test ROM and see if any PIA leg is stuck always low. then check to see if the cap is shorted to ground. That would fail a PIA test.
3 years later
#12 4 years ago
Validpowerdetect did you ever find a solution. Also have 3 flashes and cannot get around it
1,450
Nashua, NH
$ 110.00
$ 18.95
$ 100.00
$ 115.00
10,000
Santa Ana, CA
Minneapolis, MN
Gilbert, AZ
$ 10.95
$ 149.95
Allteksystems
$ 179.00
Pinball Pimp
