May have met my match with Medusa...it worked when I first got it, perfectly. Then it quit ejecting balls. The MPU had corrosion like a mofo. It was wrecked. I put a new Altek MPU in it. I rebuild one MPU connector that looked like a couple of the wires had corrosion but the rest look good. It then would eject a ball and I could play sorta but many of the lights don’t work and the upper left saucer switch triggers the ball eject into plunger...the bulb next to the solenoid expander is not lit...i changed all the fuses shown in pics so unless there is one I don’t know of those should be ok. I have put many LEDs in it but have put the siegcraft lamp driver mods in...what else do you need to know...check these pics out...lamp test is on
I can’t give up but I def need help
