(Topic ID: 235666)
eager beaver tech help
By creepykenny
4 months ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 4 months ago by creepykenny
    #1 4 months ago
    edited title for possible assistance - see post below
    any one have a scan of the eager beaver schematics that they could send me?
    almost done with this one but there are still couple things left for me to sort out and tracing these faded wires is painfully tedious
    thanks Kenny
    #2 4 months ago
    SO, i am having a problem with the right hand Blue stand up target not registering points, it does activate the "blue" relay under the play field but no points are scored, the RH Red stand up behaves correctly scoring points & activating the red relay as it should
    so its either a broken wire or a dirty switch if i can only locate it, this is where the schematic or a partial would be a huge help
    #3 4 months ago
    well, finally figured this one out, for some reason the target itself was at fault, ground lug not transferring to the grounding leafs of the target - i know not why nor do i question, i only fix or die
    with a medium sized course file i clean a side of the leaf switch stack til it shines, then flow a generous amount of fresh solder to bridge all of the grounding leaves together
    switch now works as it should
    now to figure out why the ball count stepper relay occasionally wants to bounce (yes it bounces during reset) from the ball 1 position to the ball 2 position at game start - is it the tension spring or a dirty switch some how causing this ???
    then i be done with this damn eager beaver
    #4 4 months ago
    may as well up date my own thread, ball count stepper had a sticky lever in it causing its inconsistent positioning at game starts - rubbing alcohol & cotton swabs cleaned it up rather quickly now all is fine there
    then found ball gate switch controlling the shoot again relay was shorting to its metal cover so it never turned off - easy fix with a piece of electrical tape
    next up: LH target has issues with staying in the up position & then bonus lamp stepper seems to be just a hair off
    #5 4 months ago
    to fix the hang ups and odd scoring i ended up just taking the under playfield bonus stepper apart to give it a good cleaning and it is now working 100%
    to fix the flaky LH target i had to loosen the target assembly and re position it as best as possible to the right then bend the target slightly to get it to behave so thats fixed too
    waxed & polished that nasty beaver then returned it to its rightful owner with the hopes it never darkens my doorstep again
    #6 4 months ago
    With 54 years of play and some idle times. Over time the use of, 3 in 1 oils, graphite, TV Tuner spray, or even WD-40. Will gum up most steppers.
    With this service you performed, it should run another 20 years (Hopefully).
    #7 4 months ago
    i totally agree, both steppers in the back box were frozen/locked in place by said lubricants and the under the playfield unit while it wasn't completely locked up it didn't move smoothly or freely
    should have documented & posted the flipper mech repairs & modifications i did on this one - they were really worn out in many ways,
    one of my goals was to keep the expenses to a minimum but still bring it back to life, overall the game turned out nice and played well, the little flippers being exceptionally snappy
    most of my costs ended up in the pop bumpers - other than the rings everything else had to be replaced
    $ 69.99
    $ 2.50
    Doc's Pinball Shop
    Flashinstinct
    £ 89.00
    PinballToys
    $ 229.99
    $ 239.99
    PinballBulbs
    Metal-Mods
    $ 159.99
    Great American Pinball
    $ 109.99
    Apparel - Unisex
    Pinball Wheezer
    $ 90.00
    Lighting - Under Cabinet
    $ 22.00
    $ 26.95
    $ 7,700.00
    The Flipper Room
    $ 7,199.00
    Classic Game Rooms
    $ 229.00
    $ 5,799.00
    Operation Pinball
    $ 139.95
    $ 129.00
    LED OCD
    $ 26.50
    The MOD Couple
    $ 39.95
    Little Shop Of Games
