I recently acquired a 1974 DUOTRON project game. Overall it is just about complete and appears that none of the wiring has ever been hacked up or modified. None of the fuses are blown and I was able to get it partially working and all the coils and playfield switches seem ok. The biggest problem I see is that someone got carried away with lube and it got all over the contacts for the score motor and on many other contacts. Some of it has completely gummed over some contacts. While I wait for the schematics and othe parts to arrive I want to at least clean off all the old oil and grease so those contacts are dry.
I've read it is bad to use contact cleaner but is that ok to use to get the grease and oil off if it sits for a few days afterwards? It can sit while waiting for parts. What are the best cleaners to use to get all the oil off a score motor assembly? I was thinking about putting some paper towels or rags under it, spray off all the old oil, toss the rags, and thenlet it sit to completely dry.
From there I can use paper strips and the other contact cleaning tools to carefully clean them all.
If there are any guides to getting at all the contacts for the score motor that would help. Some look like a pain to get to.
Thanks in advance for any suggestions.
