Final (big) update for a while. I'm heading off for some more time off. I have to take the opportunities that present when they present. The number of these will only get fewer as time goes by. I worked double time to get everything I could get out before leaving. I had to leave some time leftover for my own tasks as well as travel preparations.
I revised these double ROM boards. Two for System 11 (identical function) and two for WPC (identical function).
- One System 11 using 1x 27256 and 1x 27512.
- The other System 11 using 1x 27C1001.
- Both these boards require a 6264 for the SRAM (or NVRAM) to keep the settings separate.
- One WPC-89 using 1x 27C801 for OEM boards.
- One WPC-89 using 1x 27C801 for my reproduction boards.
- Both of these boards require a 62256 for the SRAM (or NVRAM) to keep the settings separate.
There is a switch that enables the LED if you want visual feedback of the state. The other switch selects between the different ROMs with an LED to indicate state. I built ROMs for Earthshaker and Whirlwind as a test of both systems. The display strobes which is why it is impossible to get an accurate image of the game name but it should be obvious.
boards_272 (resized).jpgboards_273 (resized).jpgboards_274 (resized).jpgboards_275 (resized).jpg
Same deal for WPC-89. I used Twilight Zone and Indiana Jones as a test of this system.
I had a request for the 8-Driver Auxiliary board and I had been sitting on the completed design for some time but never bothered to fabricate it.
I have been fighting this board for some time. First revision had physically incorrect alignment. Second revision had an adjustment for the alignment but I went too far in the adjustment. It also had a modification for the opto placement. This modification was to the mechanism used to make the 3D aspect of the board work. This is, without a doubt, the weirdest 3D puzzle I have had to solve in the board fabrication world. Third revision I halved the adjustment. Perfect. Free rotation.
I do take feedback and changed the lighting to allow a "wide viewing angle" or "superflux" or "Pirahna" LED. It is also possible to install a regular "T-1 3/4" or 5mm LED if you so desire. There is a potentiometer to allow brightness adjust.
And finally, everything came together because I used this test to verify the 8-Driver Auxiliary board as well as the Twilight Zone Clock board. I had to build the wiring and the power cabling to get this to work. Took a little bit of planning but everything works. It even draws from the GI (AC) and verifies the DC rectification on the Clock board. Yes. You can run the clock test on the bench.
EDIT: Re-gained access to the YouTube account so I posted the video.
While away, I will still be connected but the same caveat applies as previously. Expect slower response times. As I track everything, feel free to continue with inquiries. I will keep my work requests up to date. As a service announcement, the build queue is currently months out. If anyone does have an interest for a big board, expect a wait. Small boards or bare boards can be dealt with in short order. I have reserved April and May to play catch up on things neglected for months to years while I have been doing pretty much nothing but build boards. I might be able to use the down time during these months to figure out why the System 3-7 board doesn't work and try to get it working as well.
