(Topic ID: 79868)
Dumb switch question
By floyd1977
10 years ago
#1 10 years ago
While trying to fix my Pin*Bot target bank, I noticed the two limit switches were not the same (manual says they are both the same). Also, I managed to break the one that was actually correct. So, I ordered two new ones. The new switches have three lugs:
Common
Normally Open
Normally Closed
Am I correct in assuming that I should use "Normally Open" and "Common" for these two switches? Is this correct?
Green/Blue (Column 7) should be wired to Common
White/Blue, White/Violet (Rows 6/7 with diodes inline) should be wired to Normally Open
#2 10 years ago
Dumb switch answer here.
Yes, use "Normally Open" and "Common" for these two switches.
Disclaimer : In charge of dumb questions today.
#3 10 years ago
Thanks, Lloyd! So far, so good. I'm going to play test for a week or so and then post back on a thread I posted in a while back about the target bank not going all the way down.
The limit switch for the down position on my Pin*Bot had a much different actuator arm, and I think it might have had something to do with my issue. I also cleaned off the old grease on the two plastic parts of the target bank that slide against each other and added a bit of lithium grease.
#4 10 years ago
Here are pics of the original switches and one of the new ones. And yes, if you're wondering, I used to be a hand model.
20140206_194223.jpg20140206_194223.jpg 20140206_194250.jpg20140206_194250.jpg 20140206_194409.jpg20140206_194409.jpg
#5 10 years ago
Quoted from floyd1977:
I heard they earn top dollas
#6 10 years ago
George Costanza almost hit it big as a hand model!
2,550 (OBO)
Bethlehem, PA
$ 18.00
$ 54.99
3,000 (OBO)
Fargo, ND
3,750 (Firm)
Clovis, CA
$ 175.00
Professor Pinball
$ 18.95
$ 29.95
PinBoss Mods
$ 69.00
Pinball Pimp
$ 35.99
$ 2.50
$ 36.95
$ 39.99
4,800 (Firm)
Kingston, OK
Lighting - Backbox
Twisted Tokens
This page was printed from https://pinside.com/pinball/forum/topic/dumb-switch-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
