Took some pictures with my phone tonight. They aren't the best, but they should give an idea of what I did to fix mine. Not that I'm holding the camera in one hand, and the black lead of my meter in the other. I couldn't hold both leads and the camera, obviously.
01. I took the power plug off the drop target board and used my multimeter (set to voltage) to check the voltage here by putting each lead of the meter on the power and ground.
02. On the interconnect board, I found a place to check the +12V. Near the Williams logo, right next to this white sticker.
03. I put my meter leads to +12 and GND pads here.
04. Up to the power supply. I found out that moving these two plugs while checking the voltage at the interconnect board caused my reading to go crazy.
05. So I took the board out...
06. And flipped it over. It looked like the solder connecting the plugs to the board needed a touch up, so I resoldered all of them. It also looks like the previous owner did some work on the bottom right here. I'll have to keep an eye on that.
