So I'm new to ess pins (and pins in general) this is actually my first ess machine a 1980 gottlieb the amazing Spider-Man. My 5 bay drop target is not resetting. All targets respond and drop which triggers my 3 bay drop target reset which works fine my 3 bay also resets fine when all 3 targets are lowered. The coil is reading 3.7 ohms and is a A-17891 coil. Is this normal or is this a bad coil? Can't think of what lets could be causing them not to reset. Also bar is good and I can rest manually with ether bar or by pushing down plunger on coil Any thoughts? Thanks
