(Topic ID: 257223)
drop target question
By undrdog
3 months ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 3 months ago by undrdog
    #1 3 months ago
    This is on a Mystic. (Bally SS 1980). The ball hits the glass as often as not, off the center bank of drop targets.
    The positioning of the drop targets on this machine does not seem to be adjustable. They are in a rigid box. A tech said there would be two adjustment screws accessible from the bottom of the unit, but the only screws I see hold the parts together with no room for adjustment. I don't see any adjustment screws.
    Is it possible that a new set of plastic drop targets would fix the problem? Doesn't seem likely, I guess all drop targets are created equal, but that's all I can think of. No telling how old or new these are. They look fairly bright & clean. Incorrect design on them, though.
    Something funny about them... the flat tops on each set of drop targets are not uniform. Each of the three banks of targets has one target where the flat top of the target is slimmer than its two brothers. I'm thinking that the former owner had different sets and mixed them up. Could that be it? (Same bullseye design on each.)
    Any ideas?
    #2 3 months ago
    Could be previous owner didn’t install correct drop target or are the flippers way too strong?Also if you want adjust the game,Adjust the back legs a few inches higher
    #3 3 months ago
    There are two types of drops, ones with "hoods" and plain flat ones, each bank should have all one type but I think the different styles are just to dress it up a bit, functionally the same.
    #4 3 months ago
    Quoted from pinmike:
    Original coils on the flippers. old flipper, maybe the worn parts have a longer stroke?
    will try raising the machine up. Was thinking of doing that anyway. The captive ball shot is too easy.
    #5 3 months ago
    Quoted from undrdog:
    Yeah raising it a bit will make a difference the ball will travel a bit faster too
    #6 3 months ago
    If adjusting the tilt of the game doesn't do it then try to angle the front of the drop target assembly. Add a couple of shims (washers) under the front mounting screws.
    #7 3 months ago
    Raising the back legs all the way up didn’t help. Neither did shimming the unit.
    I give up. Hitting the glass doesn’t seem to hurt the glass or the ball.
    #8 3 months ago
    Well if you want you can put a thick clear piece of tape on that drop target
    #9 3 months ago
    I still wonder what is making it do that.
    On a set up that is not adjustable, it sure seems like it must be working as designed. One day I’ll change out the targets. Maybe new targets will fix it.
    Guess I’ll have to buy those bicycle stands folks were talking about in another thread for a rotisserie.
    amazon.com link »
    Or just live with it. The idea was to get a toy, not a new hobby project.
    #10 3 months ago
    Well if you wanted a toy that doesn't break or need work a 40 year old pinball machine maybe wasn't such a good choice.
    I think fixing them and working thru the bugs is all just part of the experience. You'll figure it out don't give up or get frustrated.
    I spent close to four days working on my Capt Fantastic Em game trying to get it playing correctly. Finally a fellow pinsider help me out and got it going. Before that I swore I'd never buy another EM game again.
    #11 3 months ago
    No, you do not need a rotisserie to solve a drop target problem. Also, people love the IDEA of owning and playing a pinball machine, but often do not realize that they are going to have both small and large issues. Those issues will require tweaking and maintenance as time ticks along...
    Without seeing the actual bank in question, my suggestion would be to put TWO rubbers behind the targets instead of one (one tapered UNDER the other) and see if that helps. It should cut down on the balls going airborne.
    #12 3 months ago
    Quoted from snyper2099:
    A complete set of new rubber is on its way. Maybe that'll fix it. Tried turning the rubber around, a few days ago, but that didn’t work.
    An older machine $$ was all I wanted to spend. Besides, I love the game.
    $ 194.99
    PinballBulbs
    $ 109.99
    $ 339.00
    $ 69.00
    The MOD Couple
    $ 89.95
    $ 9.99
    $ 76.95
    $ 9.99
    Various Other Swag
    Circus Maximus
    $ 7,499.00
    Great American Pinball
    $ 209.99
    PinballBulbs
    Apparel - Women
    Pinball Wheezer
    $ 999.00
    $ 1.95
    Various Novelties
    Pinball Wheezer
    $ 85.00
    $ 9.99
    Monster Bash Remake Out of stock
    Flip N Out Pinball
    £ 50.00
    Sillyoldelf Mods
    $ 28.00
    Pin Monk
    $ 60.00
    Whitewater pinball mods
    $ 54.99
    $ 79.00
    Lighting - Under Cabinet
    Arcade Upkeep
    $ 62.95
