Please go easy on me first time owning a Pinball table and first post on here.
The drop target inside the scull on my T2 machine is never in the up position, except if I push/pull it up or run the solenoid test
In the test menus;
The switch (77) works showing as open with the drop target up and closed with it down
The drop target knock down solenoid (12) also works it fires repeatedly in test mode and knocks down the target
The drop target reset solenoid (28) fires repeatedly in test mode and pops the target up
The only other switch I can see that could affect any of this is the gun loaded switch (31) that works as expected, no ball open, ball closed.
If I have the target up to start a game it works as normal, first ball in the skull knocks the target down and Arnie informs me we are in "Lock mode" the Database function works everything fine, next ball gets trapped and loads the gun, from here on in the target stays down, new ball or new game target steadfastly stays down.
Any suggestions welcome
