(Topic ID: 213016)
Drop Target bricking and drops upon reset Tips and Tricks
By chuckwurt
  • 68 posts
  • 12 Pinsiders participating
  • Latest reply 9 months ago by slochar
  • Topic is favorited by 15 Pinsiders
There are 68 posts in this topic. You are on page 1 of 2.
#1 4 years ago
I have been beating my head against the wall for pretty much the whole time I have been in the hobby for two issues related to drop targets of Bally and Stern early solid state games.
1. The bricking issue. This is when a hard straight on shot to the target doesn't drop. like hitting a brick wall.
2. Upon reset, one or more drop targets fall down.
I know there are various threads on these topics, but it seems there is no sure fire way to eliminate these two issues for good.
My current issue is Flight 2000. The spinner drop targets on the right are dropping upon reset what I have tried:
1. tighter springs
2. shaving a couple MMs of the drop target off to increase the lip that rests on the target housing when up.
3. putting a tighter rubber behind the targets to make sure there is nothing impeding the targets from their up travel on reset.
Here are some things I noticed when tearing them apart:
1. all of the metal arms that attach to the bottom of the drops and run in the tracks that activate the switches on the mech have been beaten in a bit.
2. the metal plate that runs along the bottom of the targets and is the plate that pushes upwards and resets the targets has grooves worn into it from hitting the arms attached to the targets over the years.
Here is my question:
Do you think the issue in this case would be that those worn parts are not allowing the targets to travel quite high enough on some resets, thus they drop immediately? Just want to see if that makes sense to others before I tear these things apart again and try new parts there.
When I get these licked, we will move onto the 1-5 countdown drops as they brick and drop on reset.
#2 4 years ago
One thing that helped me was to take movies. Then play then at half speed. Sometimes you'll see things that will give you ideas.
Mof
#3 4 years ago
Can you post some pictures of the target assembly. I have my F2K target bank tore down right now. I am having similar issues. My reset bar was broken at some point and someone added a big hunk of steel and brazed the bar together. This has caused the side of the target assembly to wear. The reset links are also worn now. I have rebuilt several target banks. I can tell you that all metal parts need to be clean. The metal stern and bally used oxidized and that oxidation causes drag. Lot of times I will tear target down and bead blast it. Make sure the ledge that the target sits on that is pulled by the solenoid is flat. If it is bent the target will slide off of it. Make sure they are clean and no oxidation is causing lip of target to stick to edge of that ledge.
#4 4 years ago
Quoted from JT-Pinball:
I’ll post pics later today when I open it back up.
But this game has been restored. You can eat off the mechs in this thing.
#5 4 years ago
Pictures still to come but I tried a couple more things:
there was some slop on the long arm that pushes up the targets on reset. I put an extra washer from spares parts from another game on it so there was less side to side play in it. that helped, but not full proof.
Then to test my worn parts theory, I put a long piece of think one-sided tape on top of this arm so that essentially the targets would be sitting up higher when the reset arm made its full travel. that improved things greatly and only got one target that still dropped upon reset (and it was only like 1 out of 5 resets).
So I am going to order new parts today.
Quoted from mof:
Gonna try this too today.
Also, do parts guides for these games exist? I cannot seem to find any. I will ask PBR today and report back.
#6 4 years ago
Quoted from chuckwurt:
1. tighter springs
(1) The bricking issue: I agree with what Vid said. Wax the lands on the target and wax the metal strap the target rests on and they will "drop like stones". Could the tighter springs you are using be part of the reason they are bricking? How do the targets act when you push them with your finger? Do they drop or seem to hang up? I don't have any of this bricking issue with any of my Sterns so I am just guessing. I don't think using a tighter rubber behind the drops would help with your issue because, IMO, the target land would be pushed clear of the strap and drop when the ball pushes the target backwards.
(2) on targets falling down, I have this issue with one of the drop targets on Seawitch not staying up some of the time. I have not messed with it yet but my thought is that the land on the target has possibly worn a little bit.
With your targets in the up position look at the opening in the play field and make sure the targets are not contacting the play field which could keep them from resetting properly. If the drop assembly is located too far forward, the targets could be riding against the opening which could affect the resetting. If they are contacting the opening in the play field you will need to relocate the drop assembly a little farther back. I would not be surprised if this is part of your problem. I'm not saying you will find drop assembly mis-located but as I continue to learn more about my Sterns, I see that parts location accuracy was not one of Stern's strong points, so don't rule this out.
I'm not sure what you are saying when you say you are using tighter springs. Do you mean you have installed new springs? Stern's Wild Fyre used longer springs but by the time Big Game came around Stern was using a shorter spring and a different way to mount the shorter springs. Steve at PBR sells both long and short springs. If you installed a spring shorter than what he sells then I could see that as part of your bricking issue.
#7 4 years ago
Quoted from cottonm4:
nope. I cut windings off the stock springs to make them tighter. Then went back to originals when there was no improvement. Anyone know what the proper assembly is for the various early sterns? I found a blow up of a mech on Marco and looked pretty different than my Big Game and also this F2K.
See this picture. Where my games differ is the target springs on on a separate rod that goes through the target bank assembly and do not attach directly to the metal arm at the bottom of each target as seen here:
So I am guessing this assembly was early EARLY stern, and F2K and Big Game were updated to shorter springs. I put an order into PBR and specified F2K so hopefully they can help.
Good tips by the way. I will look into those as well.
#8 4 years ago
Your guess is correct. That type of drop assembly is what you will see on Wild Fyre and I don't know what others. The differences are the way the longer springs attach to a hollow rod that is installed, the switches are located on the bottom instead of the back, and the target landing strap is a much larger piece on metal.
I am going to go out on a limb and say the Big Game type of assembly hit the scene with the MPU-200 pins of which Ali would be the first.
I believe Steve at PBR will know what you want for F2K.
EDIT: The differences are the way the (shorter) longer springs attach to a hollow rod that is installed... "longer" should read "shorter".
#9 4 years ago
Yes. Price is rather steep but not out of line with everything else---as the government continues to insist inflation is not happening. Sometimes you can find used ones.
http://www.marcospecialties.com/pinball-parts/STERN81PC
#10 4 years ago
Great thanks. I’m gonna get a bunch of stuff from PBR and keep at it. I’ll report back ASAP.
#11 4 years ago
does this help
#12 4 years ago
Okay great. Those are the parts I have now. Thanks.
#13 4 years ago
Another thing I've done to help targets drop was to add a little weight to the target. I glued small pieces of thick solder to the targets. This helps push the leaf switches closed.
#14 4 years ago
Wow! That’s pretty interesting. This issue leads to a lot of home made fixes it seems. Part of what makes it so frustrating. Haha
#15 4 years ago
Had a breakthrough tonight!
So the flight 2000 was almost always dropping 1 to 2 drop targets above the right spinner upon reset. When I was looking for parts I came across this picture of the really old SS sterns and their first version of the drop targets.
I noticed those springs did not use the bar across the bank to attach the spring but extended all the way down and attached to the arm attached to the bottom of the drop target.
I decided what the hell and ditched my current setup by getting rid of the bar that the springs used to attach to and attached them where they used to go on old models just like the diagram pictured above.
Almost 100% fixed now!!
The only thing that is left is one drop target will drop sometimes on reset but only if all three drops are still standing at the end of the ball. I think I know what this is, but I’ll report back to be sure.
#16 4 years ago
Yeah, that early Stern setup uses the longer springs. The later pins used the bar/tube and the shorter spring. Steve at PBR has both longs and shorts.
Thanks for coming back with the resolution.
#17 4 years ago
Yep. Here I just used the shorter springs. They seem to work fine for now. We will see long term. I’ll report back.
#18 4 years ago
Quoted from oldschoolbob:
I'm not seeing the utility of this lead weight "solution". Either you need new springs, or you have the incorrect springs or your switches are not adjusted properly.
No way do you need to add weight. The Stern drop targets work well per engineering design.
#19 4 years ago
Perhaps 30 years ago they worked well. I guess I could have replaced the targets, springs and switches with all new parts and they would have worked like new. But by adding a little weight they drop like a brick now.
#20 4 years ago
What ever works, I guess. Unless someone has taken a hammer to the switches they should be OK. They are not a high wear item.
#21 4 years ago
I had the same issue with my F2k and i had to make the plunger little bit shorter... after that... no more problem, did you change the plunger when you service hour assembly?
#22 4 years ago
Quoted from Redketchup:
In my case, a shorter plunger would have the reset arm travel higher which I don’t need. Since when the targets are all UP, and the game goes through it’s reset sequence in between balls, the reset arm is hitting the bottom of the targets that are already up, and it’s causing one or two to fall.
If anything I may need a new coil stop to limit the travel of the plunger just a hair. That might be worn in just enough to allow the plunger to travel too high upon reset.
#23 4 years ago
I understand, but mine was acting exactly like your... when i did my swap, i change the plunger because it’s was worn... the new one was longer and i have to came back with one
#24 4 years ago
Crazy. Okay well good to know. I’m unsure of the history of the plunger and coil stop. I’ll check with the restorer, but I doubt they are new. Might get a couple of each to have them to try next.
#25 4 years ago
I know you know what the Stern drop target assembly looks like but I'm going to put pics, anyway.
This is out of my Big Game. It has new short springs form Steve at PBR. When I push a target it drops. When I manually activate the plunger it pushes the targets up a little bit farther (about 1/8" / 3.175mm ) beyond the locking blade and as I let go of the plunger it drops down quickly and the targets drop down 1/8" and lock onto the blade.
The only thing I can suggest if for you to get your DT assembly on your work bench and play with it until you get it working. If it works on the bench and goes bonkers when you install it then something must be wrong with the way it is mounted to the play field. I'm sorry for the simple answer; I don't know what else you can do.
I do think if you apply wax to the landing areas on the targets and on the lock blade that it might help with your bricking problem.
On my Seawitch I am having problems with the targets in one 3-bank assembly dropping after the plunger drops. I have not looked at it yet but I"m thinking the landing areas on the targets are worn a little. But Redketchup brings up a good point with the plunger being incorrect length so I will look at that.
#26 4 years ago
Three bank on F2K fixed! Attaching the springs to the bottom of the drop targets combined with adjusting the reset arm did it.
Make sure that reset arm is level and hitting the drops evenly. Use the Allen set screws to adjust and get it lined up perfectly so that the arm contacts all the drops at the same time.
Now on to the behemoth 5 bank.....
#27 4 years ago
That's great. Thanks for posting solution.
#28 4 years ago
Worked on the 5 bank too.
However, the 1 and 4 drops are not falling from the baby coils that fire when they are supposed to. This doesn’t affect scoring or the behavior of the drops or their memory so I’m calling it done. Haha.
#29 4 years ago
Just had a bunch of friends over yesterday and put 20-30 games on flight 2k. Not one single dropped target on reset was reported and I had people looking for it. Seems to be working great! I’ll report back if anything changes.
#30 4 years ago
Nice cw, good for you.
Nothing better than a successful remedy.
Hope it holds up.
3 years later
#31 1 year ago
Hello all, trying to find some answers for an issue I am having with a target reset issue on a new Quicksilver scratch build I just purchased. I have had my "new" Quicksilver for 2 weeks and am running across all sorts of little demons that are popping up randomly since my purchase. I have been able to kind of work my way through each issue so far with help from the builder as well as people here. Unfortunately I am such a "green" pinball owner with not much knowledge of diagnosing and repairing issues. The past 2 days out of nowhere when playing my game, the center bank 4 drop targets are struggling mightily to reset themselves after they are all dropped. They seem to drop fine when hit and reset properly with no issue after the end of each ball, however during gameplay when they are all dropped sometimes it takes 2, 3 or sometimes 4 tries for them to reset to the up position almost like there is not enough power sometimes to push them back up. The arm and reset bar seem to move smoothly. I'm not sure if these pics will shed any light on the matter. I am trying my best to digest info and educate myself on being a pinball owner, but it's not been easy so far. Any help would be appreciated.
20210423_233750 (resized).jpg20210423_233758 (resized).jpg20210423_233810 (resized).jpg
#32 1 year ago
Quoted from Quicksilver1:
Hello all, trying to find some answers for an issue I am having with a target reset issue on a new Quicksilver scratch build I just purchased. I have had my "new" Quicksilver for 2 weeks and am running across all sorts of little demons that are popping up randomly since my purchase. I have been able to kind of work my way through each issue so far with help from the builder as well as people here. Unfortunately I am such a "green" pinball owner with not much knowledge of diagnosing and repairing issues. The past 2 days out of nowhere when playing my game, the center bank 4 drop targets are struggling mightily to reset themselves after they are all dropped. They seem to drop fine when hit and reset properly with no issue after the end of each ball, however during gameplay when they are all dropped sometimes it takes 2, 3 or sometimes 4 tries for them to reset to the up position almost like there is not enough power sometimes to push them back up. The arm and reset bar seem to move smoothly. I'm not sure if these pics will shed any light on the matter. I am trying my best to digest info and educate myself on being a pinball owner, but it's not been easy so far. Any help would be appreciated.[quoted image][quoted image][quoted image]
So is it only struggling if all four of the targets are down, or does it struggle with three or less down too? You can run the coil test in the diagnostics and then manually knocking down various numbers of targets before the bank resets during the test cycle to determine that.
I'd first try this easy test - check the reset arm travel by pushing in the reset solenoid plunger slowly with your finger and see if all the targets easily and evenly reset at the end. (Push in the plunger, not its link or the reset arm). If some or all of them don't, you'll need to loosen the four hex bolts (the rusty ones) and adjust the arm so that when you do the finger test, they reset with ease, and evenly. It could be out of adjustment (from normal wear or just misadjusted or someone installed a fresh coil stop, or some of the bolts were not tightened enough) where the problem is only only showing up with the extra pressure when it has to raise all four targets.
#33 1 year ago
Here's a video of the issue. I raised the playfield and tested the coil plunger and it seems to move freely and does reset all four targets evenly when pushed upward manually. At the end of every ball, the targets reset fine every time without issue for the next ball. The issue seems to be happening during gameplay for some reason.
#34 1 year ago
Your builder might not have installed the drop target assembly in a good position. From your video, it looks like the targets might be rubbing up against the play field and dragging.
I just finished with installing both of my drop assemblies yesterday. The dimples that Mirco placed on the play field cannot be trusted. If your builder used the locating dimples, that could possibly be causing your problem.
Put up a couple of pics like these two. One with targets up and one with them down.
Is there any gap between the target faces and the edge of the play field hole?
#35 1 year ago
<<Your builder might not have installed the drop target assembly in a good position. From your video, it looks like the targets might be rubbing up against the play field and dragging>>
Yeah, weird how they all partially rise, then while they are there, one here or there might drop back down. As if the reset bar went back down and the one target followed it, but the other three targets are still jammed against something.
Heh, wonder why they always act perfect-o when resetting at end of a ball though? Other than the fact that at end of ball it's always only going to have to reset three targets or less, NOT all four, and in that case it has enough oomph to power through the playfield jamming.
#36 1 year ago
That is an early style drop target assembly. Designed for use with the tombstone style drop targets. I would have used the later model shorter return springs and made another mod to that drop assembly, but either mod would probably not resolve your problem.
I hate to say this but I have to say it: This is some ugly wiring with wires floating around in all different directions. I would suggest doing some tie wrap work so those wires don't start rubbing against the springs.
#37 1 year ago
At first glance I thought that blue/white wire was going *behind* the spring. It ain't, but it still looks like it is. XD
#38 1 year ago
Here are some photos of the targets in the up position and the down position. The targets are definitely oriented more towards the front of the cut out than the back, but they are not touching the playfield on the front side, so I don't think they are rubbing. I'm puzzled as to how they worked fine for a week and a half and just started doing this a couple of days ago. It's frustrating as I paid a lot of money for this hoping that a "new" build would be less temperamental than an older one. Photo 1 is all targets "up" showing the front clearance, photo 2 is all targets "up" showing behind clearance, and photo 3 is all targets down.
20210424_214531 (resized).jpg20210424_214537 (resized).jpg20210424_214559 (resized).jpg20210424_215009 (resized).jpg
#39 1 year ago
The drop targets look OK.
The only thing I can think of is to lift the play field high enough that you can get your hand to the drop target assembly, push the targets and let them fall.
Then manipulate the lift bar and raise them back up and feel for any linkage binding.
The lift bar should raise the targets up smoothly with no drag or binding.
It might be the plunger is binding on the coil sleeve. But I don’t know. I’m guessing. But it should be smooth and free action to raise the targets back up.
#40 1 year ago
Maybe have the playfield propped up as you do the same test where they are jamming, and watch the reset plunger and reset arm, might shed some light on it. The part where some targets were partially up and then only one would drop back down looked very strange.
Check those rusty hex bolts for tightness too, if the reset rod that they bolt down on is slipping it could cause problems like that.
#41 1 year ago
So I tightened the hex bolts on the outsides of the lift bar, seemed to have fixed the issue......... for now.
1 month later
#42 1 year ago
Hey Erik,
So three years has passed. Do you still have F2K and if so would you say your solution was the proper fix? I have the same issue with bricking and one or two targets dropping down after rest on galaxy and the f2k 5-bank. I have had the assembly out of galaxy several times. Everything has been cleaned in the ultrasonic and properly reassembled (pretty sure). Since this is only happening on the banks with the pull-in coils I associated the drop down issue with the tabs on those that the target sits on when raised. Those tabs on the suspect targets seemed to be at a slight decline which led me to believe the targets where slipping off after reset. I straightened those so they are parallel which seemed to help. I actually thought i had it solved with that but they started acting up again last night. i also disconnected the pull in coils to rule out the stand up targets (which will also drop those on galaxy) and it made no difference so it definitely seems to be a mechanical issue. One thing I noticed, and it was mentioned when you were going through this before, is when the plunger is activated it seems that the targets are being pushed up too high and lean backwards at the top of the stroke. It seems like they might be missing the landing tabs on the pull in coils. the targets that are giving me problems start to lean back before the others. I need to examine, compare and probably swap in a plunger and coil stop from another game. It seems that maybe either the plunger or coil stop are too short. let me know what you think.
#43 1 year ago
Yes that was the proper fix for drops that fell upon reset. However, they brick like crazy so you have to graze them or hit them softer for them not to brick. Not terrible on that game since you really only need to go for the drops at certain times and there are other switches that spot you drops.
But I left it as the drops falling on reset was the major issue that needed fixed. Bricking I can just deal with. It’s not a game breaking issue for tournaments.
#44 1 year ago
Quoted from rcbrown316:
Hey Erik,
I have been lucky with drop targets acting as they should be acting. However, one drop assembly on this Star Gazer I am building is acting up. Here is what it is going on: Two drop assemblies work perfectly. #3 has two actions happening; During reset after a ball drain, the life action seems to lift the drops too high and 1 or 2 targets always fall down and this can be any combo of the 3 targets. However, during gameplay, when the targets are dropped and then reset, all 3 targets locate perfectly.
When doing my build, I located all 3 drop assemblies in the same manner, however, the assembly that is acting up was "pushed" forward in its location by 2 #47 bulb sockets and at first none of the 3 targets would stay standing. I took a course tooth wood rasp I got from Harbor Freight and have "filed" away some of the wood on the play field from in front of the targets. This helped some but the problem still exists, so I am going file/rasp off a little more wood from in front the the targets ( it is not as bad as it sounds. Several strokes with the rasp does not remove much wood at all.
My first choice would be to fill the holes in the play field and re-locate the reluctant drop assembly farther back by about .020" but the two #47 sockets preclude me from doing that. So, I am reduced to using the rasp.
#45 1 year ago
What do you mean with the "bottom of the drop targets"? Stern used two different length of return springs. The long spring was used on the earlier Sterns and the shorter springs with the cross tube were used on the later classic Sterns.
Here is the early style.
And the later style shorter spring.
Which way did you go?
#46 1 year ago
#47 1 year ago
I'm going to guess he went with bypassing the tube and down to the lifter arm like on the older games.
#48 1 year ago
Early style. Hence bottom of the drop target attachment instead of the middle. Made the spring tension greater, eliminating the drop down upon reset issue.
#49 1 year ago
Thanks. I have some of the longer early style springs. I will try those as well as trying to stretch out the short springs as you describe.
#50 1 year ago
I used the shorter springs. Just stretched them all the way down.
$ 5.95
The Pinball Scientist
Protection
Third Coast Pinball
Beehive Pinball Co.
Protection
Men
Displays
PinballSolutions.eu
Displays
Other
2,000
Kansas City, MO
Displays
PinballSolutions.eu
Displays
