Game Plan - Sharpshooter
Need a little help with a few targets dropping very slowly. I know I'll need to clean them, and the metal as well, but I'm uncertain as to the disassembly procedure. I "think" it goes like this, but I'm worried about bending things, and honestly, could use some guidance. Apparently if you don't own a Williams or Bally the internet/you tube has much less to offer. Who knew???
I guess the first thing would be, does Game Plan share a bank with other manufacturers, if so, I could then look them up, but I haven't found one yet.
I've removed the ring clip and white washer/cap from the rod. Now the rod seems to be stuck as I try to pull it out to release the targets. I have not removed any springs yet either, I'm assuming this is easier when the targets can move freely?
Here is what I have:
The next question would be, what should I clean the targets/metal with? Will Simple Green work for both?
I'm very excited as this fix should bring my game to 98% fully functioning (just a light socket and sound issue left).
