Reposting as the original was over a year ago and became too disjointed over time. So, problem is:
When all drop targets are down, and special lanes light. The add a game coil sticks, buzzes and the coil plunger jumps up and down. Also, the switch just below and in front of the coil arcs blue green sparks. But, hit any 100 point target on play field and it stops. Then hit 100 point again and it starts again. Or, manually engage the alternating relay switch set and it toggles the buzzing / stuck coil on and off. Also found that if the "bottom roll over adjustment" jones plug is reset from conservative to liberal, the problem still happens and hitting any 100 points doesn't toggle it off and on.
Actions taken to date to try to fix it, on the assumption that a switch / contact is open or closed when it shouldn't be: Checked every 100 point scoring play field switch multiple times. Followed schematic wiring to check every switch / contact leading to or from the add a game coil and the deduct a game coil. Checked every switch / contact on every score reel, the 100's and 10's at least twice. Checked, cleaned, gapped every playfield switch / contact of any kind. Double checked bottom roll over switches due to jones plug change mentioned above. Checked every switch contact on the score motor and on the alternating relay.
What am I missing? What pics would you like to see? (I mean of the game, get your minds out of the gutter)
