New! Dark mode!
(Topic ID: 281966)
Drilling into Addams Family CPR Playfield
By Prouddadx3
10 days ago
  • 11 posts
  • 7 Pinsiders participating
  • Latest reply 9 days ago by Prouddadx3
#1 10 days ago
Getting ready to do my first playfield swap. All prayers are welcome and if you live in Denver your welcome to the show. On the CPR website they give these directions for drilling or screwing into the playfield. "It is highly recommended to use a small BRAD-TIPPED drill bit to “start” the dimples. This prevents screw-splitting the new wood. Always use a bit size that is 20 to 40% smaller than the screw diameter itself. The screw needs something left to bite into."
Vid"s guide says to pre drill all the post holes. He does not mention the Brad-Tipped bit. I was thinking of just matching the post hole size on the old playfield. Have you guys found a certain size or type of bit that works best? I bought some collars to keep the bit from going to far. How deep do you drill? Vid also says to use a bit slightly larger than the screw which seems to be the opposite of CPR. I've built two rotisseries and have the playfields ready to go. Any advice would be greatly appreciated.
Keith
#2 10 days ago
You use the larger than the screw bit just to cut through the clearcoat. Then a smaller bit to open the dimple but not much. If you send screw in without cutting through the clear it will spider on you. I usually drill with a drill stop & dont go to far in. Hope this helps.
#3 10 days ago
Thanks that makes a lot more sense. How high up do you typically put the collar? Would you use the Brad bit first to cut through the clear coat or just a larger than screw regular bit?
#4 10 days ago
In Vid1900 guide https://pinside.com/pinball/forum/topic/vids-guide-re-populating-playfields#post-4526507 . He states a hole about 2mm deep even though the section is about reinstalling wire guides, he references for post holes also. I think there is also some play field install information on Ron Kruzmans thread. I see vid1900 guide he shows metric drill bits, I wonder if there are smaller increments in those that might be closer to the smaller holes needed like 1/16 to 3/16 for screws and posts.
#5 10 days ago
Worth a watch.
#6 10 days ago
Quoted from Prouddadx3:
Brad bit for clearcoat, a regular bit may walk on you. Let the bit do the work, I do this with a hand drill. Depth is very shallow. Ron Kruzmans kit is awesome.
#7 10 days ago
Thanks for the awesome replies and Video. I thought I had found all the videos except for a group that The Drewster has, which people raved about, unfortunately the links are dead. Has anybody found his videos archived anywhere?
#8 10 days ago
https://pinside.com/pinball/forum/topic/playfield-swap-guide
Any plans to post your progress in a new thread, so we can watch along?
-mof
#9 10 days ago
Mini hand drill 08C03.03 recommended by a fellow Pinsider
https://www.garrettwade.com/beautiful-german-made-hand-drills-gp.html
Very well made. Better control than going battery operated.
#10 10 days ago
Quoted from emsrph:
Those are actually antiques. I had no idea they were still being made. You can still find them in antiques shops all over the northeast here.
#11 9 days ago
I'm considering doing a thread from the perspective of a newbie playfield swap. Trying to simplify the process Playfield swap for dummies.
$ 14.95
