(Topic ID: 40984)
Dredd Owners Thread. Members Only!
By Anim8ormatt
9 years ago
  • 4,360 posts
  • 493 Pinsiders participating
  • Latest reply 12 hours ago by Mancave
  • Topic is favorited by 206 Pinsiders
There are 4,360 posts in this topic. You are on page 87 of 88.
#4301 3 months ago
Just joined the club. The machine is in real nice shape with no Tech alerts. It seems to play well so far. It does have the Dead World Mod. My first question is on this I was able to lock two balls on the World, but not the 3rd during play. The game did not drop the balls after the game, and when I started another game the two balls stayed on the ring. The game did not do a ball search. Is this normal for the Dead World Mod?? I am going to do a complete topside teardown for a clean and wax, change all rubbers, balls. Any suggestions on any other tweaks??
#4302 3 months ago
Quoted from smoothbore19:
That's normal behavior for the Deadworld mod, it remembers that the balls are there between games. If you turn it off and back on, it will do a ball search when you hit start and retrieve the two that were locked. If it bugs you just enable the extra ball purchase and use that to clear it out.
#4303 3 months ago
Quoted from Harrumph:
Thank you. Are there updated ROMs for sound or game play I should be looking for? I have all new rubber, tilt graphics stuff, and Coment LEDs coming. It has a Cointaker LED kit, but I need to get it lit better in the back of the playfield.
#4304 3 months ago
L7 has many bugs fixed and is the version to go to if you plan on unattended play or tournament use. L1AT (or the improved L1D) is the one with dead world locking for home play.
The only difference in sound roms I am aware of is that early versions say "dimensional lock 1/2/3" versus "dimensional phase 1/2/3". Both work with either main rom though.
#4305 3 months ago
Can some post a pic of the through 7 opto boards connectors for each board. I have new boards coming, and one of my boards has the wires saudered to the board and not in the connector.
#4306 3 months ago
Some pics of the through opto, and driver board. Even with the hacks I only have the through opto #2 tech alert. The machine does play great even with the hole in the board.
20220329_110916 (resized).jpg20220329_110928 (resized).jpg20220329_111009 (resized).jpg20220329_135531 (resized).jpg20220329_135547 (resized).jpg
#4307 3 months ago
Got a bunch of Judge Dredd parts and ramps if anyone needs something let me know.
Black Out and Stake Out ramp look good besides the entrance flaps.
Air Raid has a crack but can be repaired with Scigrip and should hold up fine.
Main Ramp is missing a chunk at the entrance but the rest looks fine.
Subway is just dirty pretty sure that is a JD part, stuff is getting all mixed up
Under playfield light thing has a crack also could be repaired and hold up fine.
#4308 87 days ago
I bent my crane while lowering the playfield. I know it's very common but I didn't know at that time. I straightened the crane shaft the best I could and put it back. Everything seems normal but now I'm having a hard time adjusting the crane to pick up the balls. Is this repair supposed to work or the tolerances are such that my only hope is to buy a new crane shaft?
#4309 87 days ago
That adjustment is a pita to do, but it should work with a slightly bent shaft too (mine isn't straight either)..
#4310 87 days ago
Quoted from cynric:
Good to hear.
My crane magnet is pretty weak compared to the videos I've seen. Is there anything I should be looking for to improve the magnet strength?
#4311 86 days ago
Make sure that you test the crane magnet during normal play. Apparently the magnet is weaker in test mode for some reason.
Quoted from clempo:
Good to hear.
#4312 86 days ago
Quoted from Preacher:
Thanks, I will keep that in mind.
I discovered the globe moves slowly whenever the magnet is on. The magnet is weak because it loses power to the globe motor. That's obviously a bad connection somewhere since my friend confirmed it does not happen on his machine. I will continue to look for the electric problem tonight.
#4313 86 days ago
Quoted from clempo:
Also you may have aready done this , but check and make sure you use that coin door clip that presses and keeps the high power button down as if the coin door is closed and allows the high power going to the coils and motors. Without it installed the crane magnet and globe motor will not have enough power to function properly. Good luck.
If this isn't something you have covered already go to my post #4011, where I posted a picture of the clip I am referring too.
#4314 86 days ago
Here are a couple of pics of my interrupter switch. The manual calls for a double switch. I believe mine has been hacked. There is no voltage cutoff when I open the coin door. Here is a couple more pics of the transformer wiring, and wiring on the left side of the cabinet. Does this look normal to anyone? Also my machine seems to work perfectly I do have the dredd world mod. I have replaced the trough opto boards as mine were hacked. I did get a through opto 2 error last night, but cleared it with a switch test. Could this be a glitch with the dredd world mod?
20220408_111441 (resized).jpg20220408_111514 (resized).jpg20220408_111609 (resized).jpg20220408_111618 (resized).jpg20220408_111635 (resized).jpg
#4315 86 days ago
Quoted from Devilsmuse:
Thanks for the advice. I now believe my crane is more affected by the globe that keeps moving than the weak magnet because the ball is no longer under the crane by the time it tries to pick it up.
#4316 85 days ago
[quoted image][quoted image][quoted image][quoted image][quoted image]
Same "lockout" behavior with my machine. Only one switch is installed, so HV remains on despite the message on the DMD. Switch, mount and wiring look just like yours, and I am pretty sure it's original. Maybe they switched to installing proper lockouts some time during early production..
Don't have the game here, but I am pretty sure the wiring harness looks also mostly the same - I do remember the round whitish connector thingies. Only the clear one in yours looks like it's been added later.
Trough errors: Pull, check and reseat the connectors to both boards at the trough before fiddling with the boards themselves, these tend to loosen over time.
#4317 85 days ago
Cynric thanks for the info. I replaced both through boards with new ones. I'll check and see if the connection came loose. On my old board two the wires were soldered right to the board
#4318 85 days ago
This is done in the factory with an intermediate connector. The factory either did not install it or it has been removed - along with the DPDT interlock switch at the coin door. If I were a betting person I suspect it was never installed at the factory. I have an Indiana Jones (not mine) in my possession that has exactly the same thing. No intermediate connector and no DPDT interlock switch.
You have a few more hacks to undo if you want to achieve factory nirvana.
#4319 84 days ago
DumbAss, thank you for the help. I think at this point since the machine functions as it should "as far as I can tell" I'll leave it be. With my luck I'd mess it up, and end up spending more on it than I would want. I already replaced the DMD board, and Driver Board with Rottendog boards. Now if I could find a new wiring harness to just replace the hacked ones I would do that.
#4320 75 days ago
Hi, after storing my JD for 5 years I have finally got around to shopping it. Pleased with the results and love the game. A few picks:
IMG_20220419_104532468_HDR (resized).jpgIMG_20220419_104549263_HDR (resized).jpgIMG_20220419_104559953_HDR (resized).jpg
#4321 75 days ago
However, I feel a bit short changed that the balls dont lock on the planet. From what I have found it seems that to make this work I need:
1. A new ring with holes rather than slot. I have a contact with a laser cutter that can probably make this for me; anyone have a dxf file available?
2. L1 or L1AT EPROM. What is the difference between them? Do I need the L1AT version? Where can I find the file? I have my own EPROM burner.
3. Modification to a opto board or creation of a small signal intercept board, and some wiring changes.
Is the above a fair summary of the work needed?
Thanks in advance for any help.
#4322 75 days ago
Quoted from Bakerman:
1. They are available for sale on pinside
2. Consider the L1-D rom as well. Search in this thread for details
3. No extra optical sensors required, just make sure all your existing ones are working properly
#4323 75 days ago
Quoted from Meldenhut:
There is also some hope that soren will also be coding a new Dredd ROM. It has been discussed in his thread. I think if it happens you will get the Dead World Locking mod of L-1 with the bug fixes/ball shooter logic of L-7. I have been holding out on doing the Dead World L-1 for this reason. He has done 7 Bally/Williams updates so far I think.
https://pinside.com/pinball/forum/topic/official-williams-and-bally-software-upgrades
#4324 75 days ago
Quoted from ReadyPO:
Having read everything Ithink that I will hold off too. Many thanks.
#4325 75 days ago
If you change your mind, the ring is also available on pinballlife https://www.pinballlife.com/search.html?Search=dredd%20ring
#4326 75 days ago
Quoted from clempo:
Thanks for the link. With postage and increasingly high import duties to the EU I think that it will be cheaper to make my own!
#4327 75 days ago
If you just want to try it, a bit of cardboard and tape on each slit in the ring can do the job.
#4328 75 days ago
Quoted from clempo:
I've got the L1-D file now so I must just have to give it a go!
#4329 74 days ago
Quoted from clempo:
You can save a few bucks by ordering the ring from my pinside shop including a few more options than this other vendor has. Plus you are supporting pinside by purchasing through a pinside shop. https://pinside.com/pinball/market/shops/1167-gameroom-mods/04276-judge-dredd-deadworld
#4330 74 days ago
Quoted from ddebuss:
Thanks. They look like great products at a great price, but shipping and EU import duties tends to make the end price much more than the part.
#4331 68 days ago
I have some mods I can have a trusted friend bring to Allentown. If interested PM.
-Judge Dredd Cooling Towers Mod by Dystopic Pinball (never installed) $90.00
-Judge Dredd Medisynl Sniper Tower - Discontinued $95.00 or Highest offer.
#4332 67 days ago
I also have:
- Judge Dredd Metal Active Crane Mod (sold by judge-dredds-pinball on eBay) $90.00
#4333 66 days ago
Just finished 3 interactive Sniper Tower mods. These fit over the original Sniper tower plastic and connect to the GI socket underneath to light the main windows and connect to the 555 quick change bulb for the sniper window, with Sniper figure, to light when the sniper is shooting in Sniper mode and on the attract mode. Includes alligator clips or cut and solder wires. $89 plus shipping.
20220427_181333 (resized).jpg20220331_143215 (resized).jpg20220427_181411 (1) (resized).jpg
#4334 66 days ago
Quoted from StarWarsTurtles:
Nice, especially since the other sniper tower mod is no longer in production.
#4335 65 days ago
I made these prototype sniper tower plastics a while ago and have some extras. They're not 100% perfect but you'll never notice it once they're on your game. $5/ea shipped to USA.
#4336 64 days ago
Just installed a pretty sweet crane mod made by Davi. I'm loving how it turned out!
#4337 63 days ago
Is there a selection in the menu somewhere to empty the pinballs from the ball trough before raising the playfield? I see there’s a selection for unloading the globe, but that’s about it. It’s a pain trying to get them out manually.
#4338 63 days ago
Quoted from binary01:
I don’t believe there is. The game doesn’t stage balls so they are all in the trough. I agree it is annoying popping them out!
#4339 63 days ago
Stick a rolled up shop towel/hand towel into the shooter lane to block the balls from rolling out as you lift the playfeild. Or better yet this is what I did: cut a strip of Styrofoam about the same width as the shooter lane and wrap it in duct tape. Just slide it into the shooter lane whenever you want to lift the playfeild.
16513744379251473292478287416398 (resized).jpg16513746021925006416303671990396 (resized).jpg
#4340 62 days ago
I bought the Mantis version of the JD ball trough and it has a closeable exit that you can flip up to keep the balls in there when you lift the playfield. I had my game fully restored, so it made sense to put in the upgraded ball trough.
#4341 58 days ago
What’s a good Ultimate Challenge score? I don’t think I’ve ever had a real good one. Tonight I had a great game, 737 million and made it to ultimate challenge both by completing the modes and by getting the jackpots in Multiball. I got 50 million each time. I’ve probably been to ultimate challenge a dozen times in the 3 months I’ve had the game and doubt I’ve ever gotten over 100 million in it, I don’t remember every score. I’m thinking the best albeit most boring strategy would be to trap up on the right and then just hit the sniper tower over and over again?
Still loving this game, very different feel to it then my other games and I don’t find the game to be as shallow as many make it out to be. Some games I’ll go multiball all day, others I’ll just go for the ultimate challenge through mode completion and pick off crime scenes while the modes are running, others I’ll try to play out every mode for the best score, and if any of that gets boring I’ll fire up a super game.
#4342 58 days ago
Great ideas for blocking the balls. I can see using the towel trick on other games also when the playfield needs to be lifted for something minor, like a quick bulb change. I did find a way to empty the balls when needed thru the menu. Go to coil test and the balls will load into the shooter lane and launch one by one - just be sure to depress the coin door switch to activate the coils.
#4343 58 days ago
Last call for the following mod that a trusted friend brought to Pinfest:
-Judge Dredd Metal Active Crane Mod (sold by judge-dredds-pinball on eBay) was $90.00 now $70.00
PM if interested.
#4344 45 days ago
Joined the club!
#4345 40 days ago
Quoted from danczaz:
Joined the club!
Whoa, I kinda like that glittery topper...Welcome!
#4347 15 days ago
Dear,
Can anyone tell me what the normal behaviour is of the lift motor ? Mine keeps going all the time after startup.
Thanks.
#4348 15 days ago
Quoted from henrigroenevelt:
Dear,
Thanks.
Are you talking about the crane? Yes, the crane searches for its position when the machine powers up. The only crane switch telling it exactly where it is is over the ring. Every other crane position is guessed with timers.
#4349 15 days ago
#4350 14 days ago
Dear,
Thanks.
When turning the game on, the crane lifts up, moves to unloading area and moves back to position that it started ( located over the side of the globe) the deadworld globe doesn't move at all during this process.
€ 90.00
Dystopic Pinball
$ 72.95
