(Topic ID: 40984)
Dredd Owners Thread. Members Only!
By Anim8ormatt
7 years ago
  • 3,563 posts
  • 407 Pinsiders participating
  • Latest reply 4 days ago by shepP
  • Topic is favorited by 162 Pinsiders
There have been 985 images uploaded to this topic. (View topic image gallery).
There are 3563 posts in this topic. You are on page 70 of 72.
#3451 69 days ago
Quoted from EvanDickson:
Hey y'all. My crane is squeaky when it moves back and forth. Can't quite tell where the squeak originates. Anyone else ever had this and cured it? If yes, what was the cure?
Yeah mine was doing that before i pulled the machine apart to re-decal. I suspect it's coming from the gearbox itself??
#3452 69 days ago
Quoted from Mancave:
I guess I have to pull that apart then. Sigh. Thanks for the confirmation!
#3453 68 days ago
Quoted from Davi:
Here is the 2nd version. No need to suffer from helicoil, no need to glue anything. Only a simple 8-32 slim hex nut and the original grub screw are required.[quoted image][quoted image][quoted image][quoted image]
What happened with this project? Will it be for sale or are you sharing the file? I just got my 3d printer back online, this would be a great one to test out the setup.
#3454 66 days ago
Has anyone on here done a black cabinet decal versions as im keen to see a judge dredd in black but cant find any pics
#3455 66 days ago
#3456 66 days ago
Quoted from arolden:
Just an update on this. The datestamp on my L2 ROMs (12 October) is one day before the datestamp on the L3 ROMs on IPDB (13 October). I am guessing nobody has ever seen this ROM revision before, so I will try and have it uploaded to IPDB.
However, after updating U2 and U3 on the sound board with the L3 ROMs from IPDB, there's a problem. When the game boots up it reads these ROMs as version P1! Anyone else have this issue before? Are the ROMs on IPDB just incorrectly labelled?
I still haven't been able to figure this out. My original L2 sound ROMs work fine but L3 ROMs from Pinwiki first read as P1, and now they just give me a sound board interface error. Anyone else had any issues with these ROM files? Or does nobody actually run L3?
#3457 66 days ago
Quoted from PinRob:
Wow those are great. Where do you get them?
#3458 66 days ago
Quoted from Mr_Frog:
Is the sound kind on these machines normally flat?
The sound on my sample game was flatter than I remembered from the prior ones. When I first got it I had no sound coming from the backbox speakers, but that was easily fixed with a new amplifier on the board.
But after that it still sounded a little muffled and flat. Had to play another one to realize mine was not right. A little research showed the large caps on the sound board would cause that. So in replacing them I found they may have been done before as part of the trace that goes trough two of the holes on the board was missing. May not have been making contact at all.
New caps and fixing that issue, and it sounds great now.
#3459 66 days ago
Quoted from o-din:
Yeah, more investigation uncovered that the sound coming from the cabinet speaker is very low, while the backbox audio sounds fine. I'm suspecting either a bad capacitor at C32 or the amp for that channel needs to be replaced. The speaker is good as it works fine in another game. I'm going to take a crack at doing some testing on the sound board this weekend.
#3460 66 days ago
I'm not sure how loud the cabinet speaker is in mine, it may not be, but what's coming out of the upper speakers sounds way better. From a distance the whole game still sounds a bit flat, but maybe that's just the way it is. Standing there playing, it is pretty crisp.
Sorry it took so long to respond, but I just fixed it day before yesterday.
It's the big caps, I believe C20 and C21 that affect it. And neither works a particular channel, they work in tandem.
#3461 66 days ago
Even with the improvement with the new caps, I've got my No Fear sitting next to it and it is much crisper and makes a louder startup bong at a lower volume setting than Judge Dredd. They use the same soundboard so I will swap them tomorrow and see if that is just the nature of the beast.
I've been a little suspect of the amplifier I used as it was an off the shelf NTE that was available local. Still way better than it was. I also read somewhere that the earliest sound rooms may not be as crisp as the later ones. Either way, swapping the boards should tell a lot.
#3462 66 days ago
Quoted from lowndes8:
My JD will be done in black when it comes up on the HEP thread later this year. I sent the black decals along with my machine to Chris for the restoration.
#3463 66 days ago
On startup my JD gets the ball on crane error and a credit dot. Only way to fix this is with a newer rom version right?
#3464 65 days ago
Quoted from RobDutch:
Ball on magnet error? Are you using the dead world mod? Is it a sample game?
I believe ball on crane magnet error refers to the switch on the crane magnet that only came on sample games. Early deadworld mods that used an extra board would cause this error.
"Switch 28 Ball on magnet
The original game was designed to use a micro switch to sense that the magnet was working well enough to pick up a ball. The switch was eliminated along with the locking feature. All that remains is a 2-pin connector that hangs down under the crane. Since the switch no longer exists, this input never toggles. According to the manual, if a switch “has NOT been actuated during ball play (for 90 balls or 30 games)”, a Check Switch error will be generated on power-up until the switch is actuated. Since there is no switch you can’t toggle it and the error will persist. The L1 prom doesn’t seem to care if switch 28 comes on when the magnet picks up a ball, but if the switch is stuck on, then it thinks the ball is stuck and it loses count of the balls. This error will not affect the game. I am presently working on a small plug in circuit to eliminate this non-fatal, nuisance error."
http://www.iobium.com/judge_dredd_locking_ring_mod.htm
#3465 65 days ago
Quoted from Guinnesstime:
pinballpt.com
#3466 65 days ago
Swapped sound boards and No Fear sounds the same. Judge Dredd now sounds a little more muffled so I guess that board needs caps too. Either way, it's not the sound board. JD with the roms I have is not as loud and crisp as No Fear. Maybe speakers or updated rooms would change that. Or it is what it is.
#3467 65 days ago
Swapped speaker panels. We have a winner!! Wow.
Who's got some speakers?
#3468 65 days ago
I have a bunch of new backbox speakers, aftermarket ones. Let me go check and snap some pics if your interested
#3469 65 days ago
Right. I figured it out. Don't know what else to say.
#3470 65 days ago
Quoted from o-din:
Right. I figured it out. Don't know what else to say.[quoted image]
WTF? One of the craziest/dumbest things I’ve ever seen! Maybe someone didn’t know how to set the volume low so they resorted to this
#3471 65 days ago
Yeah man, i'd like to think I wasted a bit of time but it's something you would never expect.
Think I might have just found the cause of why sample games might have malfunctioned and elimination ion the dead world lock.
The switch on the crane magnet uses a plastic actuator that runs thru a metal sleeve thru the coil. It has a factory molding burr on it that causes it to stick and hold the switch on causing occasions of endless multiball or an extra ball in play. Like other things can cause. Figured that out from that article I posted earlier. It's not easy to get apart, but I'm going to file the burr and put it back together. Then we are going to rock this thing.
#3472 65 days ago
Quoted from o-din:
WOW!! Baffle plates, now that's different and just when you thought you'd seen it all
#3473 65 days ago
Quoted from o-din:
That's the hardware version of:
ADJUSTMENTS -> STANDARD ADJ. -> MIN. VOL. OVERRIDE
Set to "YES".
#3474 65 days ago
Quoted from o-din:
Uh, WTF?!
#3475 65 days ago
After fixing the crane switch actuator, JD has been rocking and playing flawlessly for hours. After a good shop ad waxing it is also the fastest Dredd I've ever played. Yep that little piece of plastic might have caused many sample games to seriously malfunction. Pointless switch in the first place.
Quoted from Davi:
Set to "YES".
That was my assumption. Dumasses. Couldn't have been the music.
#3476 65 days ago
Quoted from Shredso:
Waiting for test results.
#3477 64 days ago
Quoted from o-din:
Ball on magnet error indeed. I am not using the dead world mod, and it does not have a switch there. (No proto/sample)
#3478 63 days ago
Hello
Hoping someone can help me diagnose a problem with my Judge Dredd. I have a coil that fires/activates when the machine is turned on (the START button has not been pushed). It stays activated until the machine is shut off.
The coil is the RIGHT SHOOTER. It looks like the Power Driver Assembly transistor is Q70. The Power Driver board (A-12697-3) was replaced with a Rottendog WDB089. I'm new to board issues so any help would be appreciated.
thanks
#3479 63 days ago
Quoted from fast1981:
measure the leads on q70 with a multimeter, probably shorted and needs replacing. Check your coil, maybe that’s gone bad too. There’s a diode somewhere in the q70 circuit, make sure that’s good as well.
#3480 63 days ago
If the coil has shorted it has possibly shorted out the Q70 transistor not long after. Definitely a good idea to check and change both at the same time.
#3481 62 days ago
What version ROM are you running?
My first Dredd was a production game with the early Deadworld mod and had no switch on the magnet but also had that perpetual switch error for the reasons stated in the article. Don't remember which ROM it was running, I think it had to be L-1. Without the Deadworld mod, the latest ROM should eliminate that error.
#3482 62 days ago
Hello
thanks
Thank you all for responding. You are all correct, Q70 is bad.
Looking at Q70, it has the following printed on it -
F 1C33AC
FQP
13N10L
There are 2 other transistors on the board that are not used that I would like to move (steal) for Q70. They are Q48 and Q52.
The printing on Q48 and Q52 is -
F 1D07AA
FQP
13N10L
Do you know what line 1 on these transistors means? Are these 2 transistors (F 1C33AC and F 1D07AA) the same?
#3483 62 days ago
Sounds like the rottendog uses mosfets not transistors. I never owned one, replace away. the key part # is 13N10L
11
#3484 62 days ago
Here is a new alternate translite. I wanted to make the dark judges more prominent, and to include some relevant game features on it like the sniper shot, the nuclear towers and the deadworld. Available on ebay or at a slight discount direct if interested.
#3485 62 days ago
Quoted from Pinstein:
Here is a new alternate translite. I wanted to make the dark judges more prominent, and to include some relevant game features on it like the sniper shot, the nuclear towers and the deadworld. I also wanted to make the dark judges more prominent. Available on ebay or at a slight discount direct if interested.
Looks really cool My only question is how well does the GI and flashers behind the translite integrate with the images? I'm absolutely NOT having a crack at your efforts btw it really does look awesome!! I'm going off my own past use of alternative translites where for some, the led's just didn't quite marry up with the new images.
#3486 62 days ago
Thanks! I wouldnt let the lie of the lamps dictate the layout of the art. How it may align with the factory array but with comets matrix system its super easy to move lights and flashers anywhere you want them.
#3487 62 days ago
Pinstein - definitely the nicest alt translite for this game ever done... can you post some photos of it installed with the game powered up? It would be nice to be able to judge (pun intended) the translucency - whether or not it is too dark (easier to fix with brighter bulbs) or if it lets too much light through and looks washed out.
Very interested party here!
#3488 62 days ago
Unfortunately, I don't own a JD. I used to some years ago but that was when I was rifling through games and too caught up in the hobby. I am looking for a JD again though. Here is a mock up of it on the game. I would also like to redo the speaker panel to have the DMD be the display on the lawmaster motorcycle. Kind of a first person view much like the coindoor. I will have to track down those black decals once I find a JD. The print quality is specifically profiled for backlighting.
#3489 61 days ago
Quoted from Kneissl:
A sincere thank you to kneissl Your advice was spot-on!
#3490 61 days ago
I'm addicted to this game. To me, it shoots a lot like Maiden, but has more shots. Code isn't as deep, but Maiden code isn't super deep either. There's just "more code".
#3491 61 days ago
Way better music too.
#3492 50 days ago
I keep forgetting to post here and "officially" join the club.
My game arrived with the GI connectors burnt out. I've since fixed that but took adding more light to the playfield a step further by modifying the drop target bank. Translucent targets were acquired from www.pinball-mods.com and I had some decals I designed cut.
Pictures are better than words:
5J5A3088 (resized).JPG5J5A3089 (resized).JPG5J5A3092 (resized).JPG5J5A3133 (resized).JPG
Four of the targets had to be modified to fit; more details can be found as I describe going thru the game here:
https://pinside.com/pinball/forum/topic/project-paragon-breathing-life-back-into-the-beast/page/13#post-5407829
I know it says "Paragon" -- you'll just have to trust me.
#3493 41 days ago
Available in the shop, a new version with small holes like the original one!
thanks.
#3494 38 days ago
This may very well be the first alternative translite where, upon first seeing it, I immediately thought "wow that looks nice". Good job!
#3495 36 days ago
For those of you that have a colorDMD in your machine, did you choose the LCD or LED version, and why? I'm going to get one here soon for my Dredd, but I'm not sure which one I want to get. I've seen both and LED works well for some games and LCD for others. Can you post some pics?
#3496 36 days ago
LCD no reason just always bought the LCD version...
#3497 36 days ago
I highly recommend LCD for Judge Dredd. I went LED when I had mine, based on how much I like it in Dracula, but I believe the high res smoothing on the LCD is the way to go for the JD comic style.
#3498 36 days ago
Yeah, OK that makes sense. That pic kind of seals the deal for me. Thanks!
#3499 36 days ago
I really like LED for older games. I have it in Dredd and it’s great.
#3500 35 days ago
I went with LED in my JD since I prefer the original DMD look vs the smoothing effect on the lcd version.
$ 279.95
Pin Stadium Pinball LEDs
Raleigh, NC
$ 12.00
$ 29.50
Playfield - Plastics
