Judge Dredd
Game ROM Revision History
Provided by: Action Pinball & Amusement, LLC
Web: www.actionpinball.com
Version L-7
Date: January 6, 1994
U6: Checksum: 9A07
Changes from revision L-6:
Fixed pricing for Italy buy-in.
Improved the ball shooter logic -- left and right.
Fixed the SuperGame replay level calculation.
Added a ball saver timer adjustment.
Added coin door interlock message.
NOTE: To use Custom Pricing on this game, you must set the
dipswitches on the CPU board to Export (1-5 off, 6 on, 7 off, 8 on)
Version L-6
Date: October 12, 1993
U6: Checksum: 1906
Changes from revision L-5:
Changed "lock ball" message due to rule change.
Changed USA default pricing from $0.50 to 6/$2
Fixed planet test switch number.
Switch 28 (not used) no longer shows up in test report.
Increased delays between firing of certain coils to reduce
stress on the coil fuse.
Version L-5
Date: September 27, 1993
U6: Checksum: 2D05
Changes from revision L-4:
Added audits on left and right drains.
Left ramp enter switch no longer reports errors.
Improved right ball shooter logic.
Version L-4
Date: September 8, 1993
U6: Checksum: 5004
Changes from revision L-3:
USA pricing fix.
Version L-3
Date: August 30, 1993
U6: Checksum: 5103
Changes from revision L-2:
German pricing fix.
Version L-2
Date: August 25, 1993
U6: Checksum: 5702
Changes from revision L-1:
Balls are no longer locked on planet ring.
Version L-1
Date: August 18, 1993
U6: Checksum: 5702
Initial release for production.
