Quoted from Mancave:Yeah checked the shooter lane switch with either Rom installed and works in test mode on both. You're right though, if the trough plug/s were an issue then changing Rom wouldn't make a difference, they still would play up. Just ran a full switch/opto test again, first with the normal Rom installed and then with the Dead World Rom installed, results were the same with both Roms.....yet the problem still exists with the Deadworld Rom in multi ball
Super game is still ok but after multi ball is started in regular game the problem arises. In regular game it starts with just the one ball (as per normal), knock the targets down in sequence to start the ball lock mode (as per normal), roll 3 balls into the ring and the machine shoots the 4th ball whilst the crane starts to unload the ring (as per normal) (NOTE* i have checked the crane ball drop manually in switch test just to check that the ball is actually triggering the opto and yup, works), when all 4 balls are in play and you lose 3 it ends BIP (NOT normal). When you start the next BIP the machine throws out several balls into the shooter lane just like it would with a trough opto error
At this stage i can't think of anything else to do but perhaps get some after market trough boards and see if that changes anything, if the Rom can't go bad there's no point in buying another Dead World Mod ( for another L1AT Rom). I've had this machine for a few years now, even bought another project machine, restored and fixed that one up and sold it. This is the weirdest, seemingly unexplainable issue i have encountered so far
I'll note that my Dredd has been doing 100% exactly as you've noted in your posts (since I installed the Deadworld mod with L1AT). I figured it was an opto/trough issue that I'd delve into at some point, but now I'm wondering otherwise. Hmmm.
