This is my custom dragon Ball z pinball machine I have been working on for almost 3 months pretty much non-stop after work, it's a mostly em pinball with some solid state flare from Amazon to help out with timing certain relays so I can get away from using a stepper it has a combination of MP3 triggers and chimes I got all of my pinball specific mechanisms and parts from pinball life, what really got it going quickly was having a WPC donor cab. I fired it up yesterday and after a few head scratchers I'm proud to say it's fully functional the way I designed it. Now I've got to work on getting that second playfield with art finished and getting a translite.
Rules: pretty simple rules here all the orange targets stand for one dragon Ball on the backboard if you hit those the dragon Ball lights up and holds if you get all seven you get an extra ball white targets pull in a chime and score a point or I can tie them to a different circuit that decrements a point under the playfield using a Pac-Man connector, I went super simple with a single point scoring system so I designed shots to score multiple points with multiple switches-the left side is made for a captive ball that isn't there, for instance that shot will score 3pts same for the top loop- the main feature is super Saiyan mode you have to make all three DBZ Lanes up top and then shoot Goku the GI will turn yellow and the spinners will be enabled which is huge points on my scoring system.
IMG_20201102_193523377 (resized).jpgIMG_20201102_193808717 (resized).jpgIMG_20201102_193818793 (resized).jpgIMG_20201111_141226360 (resized).jpgIMG_20201111_164643408 (resized).jpgIMG_20201111_203027107 (resized).jpg
