Hi need some help working on a gottlieb dragon system 1. I am adding three fuses to the small transformer the mod is from pinrepair. I have added a 2amp slow blow fuse to lug 6 and a 3/4 fast blow fuse to lug 7. The problem I am having is on pinrepair it talks about adding a 1 amp fuse to the 120 volt. The transformer I have, the brown wire is connected to 115 volts . Would that be the right lug and wire and if it is then is a 1amp fuse still the right fuse to use. If anyone can help out it would be great I just want to make sure I get this right. Ps the machine is wired to Australian standards. Thanks in advance.
Raff
