I'm having an issue with the secondary opto board on BSD. The emitter for the most beam going across the playfield does not get proper power. The 2 pin connector on the board (J2) shows about 6v-8v without the emitter LED connected, and it shows virtually nothing with it connected. I tested the receiver with a light and its not that. The wires running to other optos in the game show 14v (12v unregulated) without a connection and about 1.3v with the emitter connected. I swapped emitters around and also found that the emitter itself is bad.
The MC1455P1 timing IC in the emitter power supply circuit is suspect, as we replaced the 2 caps on the board and tested various diodes and resistors without solving the problem. The chip is getting 14v on the Vcc supply pin and about 8v on the chip's output leg of that chip (see data sheet). Obviously there is something wrong with the chip? Can someone confirm this?
