hi all
my buddy has a BSD and he has to change the batteries every month. Any one have any ideas on the cause/fix?
See if this might be the issue: http://pinwiki.com/wiki/index.php?title=Williams_WPC#Settings_Not_Held_or_Battery_Depletes_Rapidly
this is usually a shorted blocking diode. test the diodes around the battery looking for one shorted in both directions.
Quoted from busa32927:can you test diodes in circuit?
in this case yes. Because there is nothing in parallel across it.
you cannot test a diode in circuit on something like a solenoid coil because of the being across the low resistance of the solenoid.
Any one know what common kind of lithium batteries are used? I took mine out to get a replacement and misplaced it. It was the size of a nickel and 4 numbers.
This page was printed from https://pinside.com/pinball/forum/topic/dracula-draining-batteries and we tried optimising it for printing. Some page elements may have been deliberately hidden.
