(Topic ID: 221646)
Dracula - Check Fuses F114 & F115
By jeffdill
5 years ago
  • 17 posts
  • 10 Pinsiders participating
  • Latest reply 5 years ago by jeffdill
#1 5 years ago
This is my first pin and I'm completely new to maintenance. Me and a buddy cleaned the playfield, replaced some bulbs and rubbers, and soldered one of the wires on the center 3 bank. I am now getting the "Check Fuses F114 & F115" error message. The very last thing we did before this error happened was replace the two GI bulbs on the left bumper...I gave that area and the solder area a good look over and they seem totally normal.
The fuses seem fine to me, so I'm not sure if a short is the issue or what. One time when I turned it on it gave a quick message of "GR1 short" or something like that, but I couldn't replicate that. I'm hoping someone else had the same issue on the pin and knows how to fix it. I unfortunately don't have a voltmeter on hand at the moment.
#2 5 years ago
Seem fine isn't good enough - pull and check with a meter.
If fuse is good, then this : http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Check_fuses_F114_and_F115_message
#3 5 years ago
So, I am a visual learner with someone explaining things to me, and your problem is covered by the Pinball Ninja website, with a couple excellent videos that can walk you through the Pinwiki steps in LTG's post above.
If you follow the PinWiki instructions, awesome - but if not - I would HIGHLY recommend paying $20 and having lifetime access to one of the absolute best repositories of information in the world. This exact problem is covered at least 8 times on each website over 6 or so games with TZ getting the honor of repeated diagnosis.
I am in no way associated with the website nor do I get kickbacks. I just know an INCREDIBLE source of information when I see it, and with his YT videos set to private with access only through the site, it is well worth the $20 admission.
http://www.pinballninja.com
#4 5 years ago
Purchase a cheap voltmeter would be helpful.
I do see the 12V digital voltage LED is not lit and F115 looks like it may be blown, but it also could be dirt I am seeing through the fuse that is on the fuse holder. Testing with a meter would be the best thing to do. You can replace it with a slo-blo 3/4 amp 250v fuse. If you replace the fuse and the LED is still not lit, then your C2 likely had failed and eaten up the pad/trace under it breaking the connection to the F115 fuse. In any case, you should replace C2 (100uf 35v or 50v electrolytic capacitor) anyway.
#5 5 years ago
Thank you...I'll purchase one and keep working at this. Frustrating since I didn't buy it very long ago! I got a good deal on it though, so I can't complain.
#6 5 years ago
Ok so I got a multimeter and tested the fuses. F114 is definitely ok, F115 is definitely blown. Per the wiki I unplugged J210 and tried it, the fuse didn't blow.
Upon closer inspection, I see some corrosion on a couple of those chips. Could that be the cause? Are those replaceable?
#7 5 years ago
Quoted from jeffdill:
And the battery holder, and under the battery holder, and leaching down.
Check with a pro if it can be repaired or cheaper to replace.
#8 5 years ago
Nice roofing nail in the battery holder....get those batteries outta there, and buy a remote holder. Use vinegar and a toothbrush to neutralize the corrosion. Rinse with a lot of water, then use 90% isopropyl to displace the water, fan dry.
And give a couple days to really dry!
#9 5 years ago
Board is done. Get a replacement MPU, Rottendog WPC89
http://www.bigdaddy-enterprises.com/
#10 5 years ago
Now, ya gotta love the roofing nail in the battery holder.
#11 5 years ago
Quoted from Phat_Jay:
Can corrosion like be the root cause of the short, or is it likely that I have another issue I haven't found yet? Just seeing if I should hold off on part ordering until I know everything I need.
#12 5 years ago
Quoted from wdennie:
Ha! I can't take credit for that one, it was like that when I bought it. Worked totally fine until recently.
#13 5 years ago
Battery corrosion can cause all types of issues, including yours. Get that board repaired - remove the batteries at a minimum to remove the source, then research on this site on how to remove the corrosion. Lots of advice out there. A spare board is always needed.
1 month later
#14 5 years ago
Life got in the way so I hadn't been working on this, but I think I confirmed that the corrosion fried my MPU board. I replaced the board from my friend's Judge Dredd and the game worked fine (no display on the DMD, but I probably just forgot to connect a cable). Guess I just need to buy a new board.
#15 5 years ago
If you end up purchasing a new board and plan to dispose of the old board I would be interested in it (I'm local to you). Feel free to PM me if so.
#16 5 years ago
Or send your existing board out for repair. Barakandl, Chris Hibler, Coin-Op Cauldron are a few good people to send your board to for repair. I find the original boards are typically fine for years once gone over by a pro.
#17 5 years ago
Good news and bad news. I swapped the board out with the new Rottendog board. Right now the flippers don't work, or the left sling, and when I first turn the game on it goes into ball search until I let the Mist ball drain into the trough. I went through and tested the other switches and I think they all work fine. Still feels like progress!
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 329.99
$ 27.95
$ 49.99
$ 17.50
$ 5.00
9,500 (Firm)
South Bound Brook, NJ
YouBentMyWookie
$ 12.00
$ 19.95
SilverBall Designs
Omaha, NE
$ 5.00
Metal-Mods
$ 399.00
$ 119.99
FlyLand Designs
Metal-Mods
€ 45.00
Kami's Pinball Parts
$ 259.99
$ 18.95
$ 1,059.00
Lee's Parts
$ 46.99
Lee's Parts
$ 84.99
$ 9.99
$ 17.50
$ 109.99
This page was printed from https://pinside.com/pinball/forum/topic/dracula-check-fuses-f114-amp-f115 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
