Listen closely as you put the game in test. If you hear the motor moving, could be a broken gearbox. If you don't hear the motor, think electrical.
The playfield moves up and down via a 20 V DC motor. The motor receives power from a bi-directional driver board that flips the polarity to drive the motor CW/CCW.
Could be a simple connector issue, break in the wire or more serious.
Start at the motor and work backwards to the Bi-Directional board looking for a wire break. If this tests out good hook a DMM to the motor contacts and put the game in test....see if 20V is making it's way to the motor (motor could be shot).
Checking the gearbox requires pulling the MPF. Let us know what happens with these tests first.
faz
