(Topic ID: 97673)
Dr Who Mini PF not working
By robm
9 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by KingBee
#1 9 years ago
Hi All,
Have a Dr Who with Mini PF not working at all during mini pf test or gameplay. Things i have done:
Completely stripped and cleaned mini pf
Use 12V battery, mini pf works fine when connected to this, moves smoothly
Swapped CPU with known 100% working one - same issue, Mini pf does not work
Swapped Power Driver board with known working one - same issue, Mini pf does not work
Swapped Motor driver board with known working one - same issue, Mini pf does not work
Triple checked connector plugs to and from motor driver board
Continuity from motor to motor driver board is fine (although i when i put one lead on red motor wire, it gets continuity to both red and black on motor driver board)
Fuses all test good (tested out of machine)
Home opto on mini pf works fine in switch edges
Playfield glass switch is fine, and i push this down during testing
All other functions of mini pf work (kickers and flasher)
This was a machine left in storage for many years, so i have also cleaned the whole machine down - it did actually work a couple of times when i first put it all back together.
Only other strange one i could think of was maybe a dodgy ROM?
Any ideas as i seem to exhausted all possibilities....
Rob
#2 9 years ago
Also, i have 20v going into the motor driver board
#3 9 years ago
The pf safety switch is shown as closed in the switch test? Because with all you have mentioned it should work. I would probably short the wires to,the switch together and see if it works.
#4 9 years ago
Quoted from dsuperbee:
+1 for this...actually, check all switches. All the optos in the MPF need to react properly or it just won't work.
Also, it could just be that the connector to the motor is shot. Mine crapped out just before a party. The MPF would not move and it was the connector finally giving out. I pulled the pins and clipped it for the party. New connector pins and good as new.
Good luck!
faz
#5 9 years ago
Try checking and reseating the ribbon cables in the back box. This fixed a problem I was having with mine.
3,700 (Firm)
Ronkonkoma, NY
$ 329.99
$ 199.95
PinSound
$ 9.99
5,750
Bartlett, IL
3,500 (OBO)
Johnson City, TN
£ 110.00
$ 14.95
$ 29.50
Playfield - Plastics
$ 69.50
$ 109.99
$ 27.50
$ 40.00
4,800
Mt Zion, IL
$ 9.95
$ 27.95
YouBentMyWookie
This page was printed from https://pinside.com/pinball/forum/topic/dr-who-mini-pf-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
