New! Dark mode!
(Topic ID: 188769)
Dr. Who audio board cap exploded
By RocketFromTombs
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by RocketFromTombs
#1 3 years ago
I originally posted this in the Dr. Who owners club thread, and was directed here...
Okay, I've got a Dr. Who that has been sitting in the basement for a couple of years. Decided yesterday to turn it on and see what happened... Got the "factory settings restored", which I expected, as the batteries haven't been touched. Also, as I was going through the tests, the machine would keep resetting. I'm guessing something is taking down the 5v, but as I was doing a quick check on stuff, there was a sudden sparking over by the audio board/fliptronics board area. Quickly turned it off, and investigated to find this on the audio board:
C26 is exploderated! Any ideas what I should be checking out next?
-Brian, off to find the correct schematics for the audio board.
#2 3 years ago
C26 is a tantalum capacitor. They just have a habit of exploding after long periods of no use.
#3 3 years ago
It appears to be... Doesn't look like an electrolytic or poly. Should I just replace it and continue with my reset troubleshooting then? Should I stay with tantalum or switch to something else?
-Brian
#4 3 years ago
Quoted from RocketFromTombs:
-Brian
Replace with another tantalum and continue troubleshooting. It's more than likely that the cap just failed.
#5 3 years ago
Exactly the same thing happened on my two CFTBL machines after I have pulled them out of storage after a few (7) years hibernation. I have replaced the caps and everything was fine.
#6 3 years ago
Quoted from arolden:
True. It is worth changing the other same value tantalum caps as well.
#7 3 years ago
Good to know.
#8 3 years ago
Thanks everyone,
I'll replace those caps and continue with my reset issues.
- Brian
#9 3 years ago
Tantalum does not ripple or being close to the voltage rating, surges... Or they explode... violently.
Use a higher voltage rating tantalum. Electro is also probably acceptable. I would increase the uF slightly and voltage rating for electro cap.
#10 3 years ago
New tantalum caps arrived today. I'll replace them later this week and then continue with troubleshooting the 5V. Thanks!
-Brian
$ 50.00
