New! Dark mode!
(Topic ID: 269243)
Dr Evil bash target not registering
By jsharpe005
5 months ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 4 months ago by jsharpe005
#1 5 months ago
Just replaced Dr Evil in Austin Powers and now it’s near impossible to register hitting him while playing. First photo shows current distance to connect switch. I do not know where the piece hanging over the edge in the 2nd photo goes and could use some help in figuring out how to get back to bashing this evil genius. Thanks to all.
7DF3439D-DFA6-4005-BAD6-39D3BA7B1764 (resized).jpeg23420834-AB47-4D96-B78D-9C592914621A (resized).jpeg
#2 4 months ago
Mine is on location and were closed up so maybe someone else can check. I think your switch may be mounted upside down. That metal plate on the top of your switch is most likely keeping the blades from fully flexing and making proper contact. Make sure you dont have any cold solder joints on it, I would cut that slip connector off and solder it directly to the blade. Also your gap between contacts is way to big. When mine was giving me trouble I had to use a leaf switch adjuster from the top side of the playfield and left the gap very narrow, about 1/32" between the contacts. Trying to adjust it from the bottom of the playfield led to alot of profanity as I couldn't get the gap correct.
#3 4 months ago
Appreciate the help. Will try.
#4 4 months ago
Got it working good now. Was not mounted upside down but definitely too much of a gap between contacts. Adjusted contacts, with leaf adjusting tool, to barely touching while the playfield was vertical (gravity). Bringing playfield down created the perfect small gap and now I am back to bashing Dr. Evil and keeping the world safe.
4,100
Louisville, KY
$ 65.00
Lighting - Backbox
Arcade Upkeep
Pinball Pimp
$ 54.99
$ 208.87
$ 54.99
Gweem's Mods
$ 22.00
PinSound
