Hey all,
I've recently purchased my first pin, Dr. Dude, and unfortunately I've run into some issues. Currently:
1) The mixmaster always spins.
2) The ball won't load into the shooter lane.
3) Targets set off things they shouldn't (example: heart of rock and roll sets off the knocker).
This was a 100% working machine before I moved it in my house, but I guess something got messed up during the transfer.
I've been going through the machine and reading online, and when going through the switch test I get the error "A/C Relay C-Side 06 02." (see screenshot). I am fairly certain it is a wiring issues as I have removed the j8 and j10 connectors (iirc) to determine if the board was at fault.
Also, I found a section on this site http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11 which suggested checking fuses under the section 4.6 Solenoid problems. They all looked ok.
I got confused when looking through the manual at the switch matrix section. Does anyone have an ideas where I can look or what I can test?
When I get home from work I can provide a video of the behavior if it helps. Thanks in advance and sorry if this is all basic newbie stuff.
EDIT:
Post edited by Applesaucesomer: Insert a video
