I have a Dr. Dude that if right, left or both flippers are energized and you hit switch 50 magnet target and magnet solenoid #13 energizes and it holds the ball in place, and if I release the flipper buttons, it will cause 1 or both flippers to stay energized until the magnet time runs out, then the flippers will release at the same time the ball releases. This will happen every time.
I have changed out the Auxiliary Power Board, no change.
Changed out the Backbox Interconnect Board, with no change.
I have pulled all 3 wires, one at a time from the High Current Driver Board all the way through to where they go into the boards in the head and tested after each one, thinking maybe a solder splash in harness. No change.
When I unplugged the High Current Driver Board and hit the switch 50, the flippers work like they should.
If I hold the flippers up with my hand and energized the magnet and let go, the ball is energized on the magnet and the flippers will fall like they should.
Any other ideas of what it could be or what I should try?
Thanks John
