Quoted from mrgregb123:Ouch. That's right in the middle of the playfield and is halftoned paint (the pixels). You CAN fix that with a decal. Because it's in a prime area, you really gotta color match it well. OR What I would do is color match the blue part and simply manually touch it up with Createx paint on a very thin brush. I'm a picky person but when done right nobody will be able to tell. For the black parts, use a Molotow marker.
I'm very surprised the mylar lifted that and you aren't also having clear coat detachment issues on the inserts (which you'd notice right away)
And that's only one little section. And most is in the halftoned areas. I feel really bad for the owner cause the pin is in super shape besides the paint lift.
Yes, my resto guy said waterslide decals could possibly be made to match the half toned areas. But, I don't know for sure Dr. Dude was a pin I wanted to spend the money for to clear, etc. like I did my taxi (keeper for me).
I know owner used heat to remove the mylar. I've always used freezing and never had an issue. I do know this era of ballys is prone to paint lift.
