(Topic ID: 259361)
Dr. Dude - all segments show '0' on display
By JKirby
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by Blake
    #1 4 years ago
    Good Morning Everyone,
    Working on a Dr. Dude - the left hand display shows all '0' from startup. I get other activity on the segments as the game plays, but I can't tell if its' correct. Anything I should be on the lookout for?
    Thanks,
    Joe
    #2 4 years ago
    Did the display just stop working?
    Does it cycle through the high scores or spell out Dr. Dude? Does it show an error message (batteries died/not good connection), Does it function properly in test/adjustment screens? Does it function properly during gameplay? You said it has other activity but is it at random and does it make sense?
    If the display is showing all zeros and the segments look bright and are full then that rules out quite a bit. Your probably not looking at a power issue (100vdc + and 100vdc-), its probably not a short or a bad cap, transistor, exc.
    I would be looking at the ribbon cables and confirm there is good connection and are properly plugged in. I also would confirm the slam tilt (if installed) is not closed.
    Try swapping displays. (power off. Careful HV)
    Maybe a quick vid of the display upon boot up would be good too.
    Blake
    This page was printed from https://pinside.com/pinball/forum/topic/dr-dude-all-segments-show-0-on-display and we tried optimising it for printing. Some page elements may have been deliberately hidden.
