<MapleSyrup said:
I'm having issues with ball searching. Anybody else??
When 3 balls are locked in the Munchinland ramp, sometimes the machine doesn't kick a ball out, goes in to search mode, but never tries releasing a ball from the ramp lock??!
I'm not sure what's causing this. Must be a software issue. I hope I'm describing it correctly.
I've had to restart several times as consecutive ball searches can't locate my ball.>
<<That is exactly the problem I am having. I am going to look at my pin to see if anything is wrong, and perhaps try to recreate this with the glass off.
If nothing helps, I am opening a ticket with JJP. Keep me posted on your resolution of this problem and I will do the same.>>
I had a very similar problem, had me stumped too, but then I found that it was directly related to the adjustment of the gap between the magnet coil and plate on the arm lock, once I got it adjusted correctly it's been perfect since. The reason I think that it didn't work in ball search was the pulse to the coil isn't as strong, so it doesn't have enough pull to make the arm rise.
I could be completely wrong on this, but it has worked for me, super easy adjustment so worth a try?
