I just read where someone gave advice to use Windex on plastics and plastic ramps. This is bad advice, if used on plastics it will discolor them. Windex is for glass, Novus is for plastics!!
Windex can cause certain types of plastics to "cloud". Soap and water or mix of Simple Green and water will work.
Was a big no-no on the race care with lexan windows also. I think the ammonia would kinda attack and soften the plastic...eventually making it dull/cloudy.
Nothing a torch couldn't fix though
The ammonia in certain types of glass cleaners attacks lexan. Makes it cloudy and brittle. That is one of the first things our Aero club tells us. DO NOT use glass cleaner on the windshield.
I would say avoid Novus on plastics with art, the Novus is like very fine liquid sandpaper. I use technical grade alcohol (99.9% anhydrous alcohol). Tech grade alcohol also cleans rubber parts up very nicely.
Quoted from wayout440:I would say avoid Novus on plastics with art, the Novus is like very fine liquid sandpaper. I use technical grade alcohol (99.9% anhydrous alcohol). Tech grade alcohol also cleans rubber parts up very nicely.
Don't use alcohol on older plastics unless you know it's safe. Alcohol softens the plastic on Williams EMs enough that you can leave a finger print in it. I don't know when things changed or which other manuf. used that type of plastic.
Novus 1 isn't abrasive and seems to be fine for the art side of plastics, but as someone said above mild dish soap should also work.
Novus 2 and 3 are abrasive. Novus 1 is just a polish. I use it on plastics with art all the time. Never had a problem.
We could never figure out why my grandmother's glasses always looked like shit even when they were only a few weeks old. Then one of us caught her cleaning the lenses with Windex. It would cloud up the lenses after only a few quick applications that were quickly wiped off.
I think lenses are mostly made of polycarbonate these days but I would not be surprised to find out that Windex type products attack most plastic and make it cloudy.
I don't think she ever came to terms with the idea that her "glasses" were not made of glass any more.
Calm down. Don't panic.
That was me. Guilty as charged. But seriously, it doesn't do any harm unless you let it sit on a surface for a while like you do with wax. How do I know? Because I've used it in a pinch many times for a quick wipe. If you wipe it down with a clean cloth right after, it actually leaves a pretty damn nice shine and cleans off dirt nice and quick. Again, I know this from having used it on my Cyclone's ramps 10 YEARS AGO for a quick wipe down that are still clear as crystal.
I have never seen Windex do any harm to anything I ever used it on and I have shopped over 20 machines. Just talking from experience. There are without a doubt better products to use, but if you use it or have used it, I really wouldn't panic.
That said, if others have had problems, might as well just avoid it all together - not worth the risk. Just don't want anybody to freak out if they used it once or twice.
-BB
Quoted from Pinwizkid:I have never seen Windex do any harm to anything I ever used it on and I have shopped over 20 machines. Just talking from experience. There are without a doubt better products to use, but if you use it or have used it, I really wouldn't panic.
Amen. I used Windex on my subway ramp for my TZ and it came out perfect. I firmly believe that it all comes down to technique. You cannot leave any residue on it, you have to wipe it dry with a separate, dry towel, and wipe after it's dry. It's just the way you do it to achieve that shine you're looking for. I come from a long history of waxing and polishing cars and know the proper laying down/picking up techniques of hand applying cleaning materials. Technique is everything!
You know those paper towel commercials you see on TV? That's a trained hand working those things. I guarantee both towels could do that job if the person wiped exactly the same way for both towels.
If you're unsure about the technique, or ammonia content of what you're using, it's safest just to use Novus and not even worry about it.
Regular Windex doesn't have ammonia, does it? I've been using it for decades to clean ramps and plastics.
I've NEVER had any trouble using Windex on plastics, and I'll keep on using it if you guys don't mind.
Quoted from mg81:We could never figure out why my grandmother's glasses always looked like shit even when they were only a few weeks old. Then one of us caught her cleaning the lenses with Windex. It would cloud up the lenses after only a few quick applications that were quickly wiped off.
I think the issue with using Windex on polycarbonate eyeglasses is it attacks the coatings used on them. Modern eyeglasses have coatings for scratch-resistance, anti-fog, anti-glare, UV and other characteristics. It really doesn't hurt the polycarbonate as much as it affects the clarity of the coatings used.
Quoted from Foo:Plexus and a microfiber towel.... perfect for plastics and motorcycle helmet shields
yep, best stuff to use, it cleans plastics very well. i use it on a quick wipe down of all my rubber rings also, and on stand-up targets. lucky for me i have cans of this stuff left over from my paintball shop, it was the cleaner of choice to clean paintball google lenses without the risk of weakening the lenses.
Quoted from pinstyle:yep, best stuff to use, it cleans plastics very well.
I use it nearly every day from spring to Fall... right before I ride. I can't wait for Spring!
Quoted from Ballsofsteel:I use windex on my pf glass. is that bad too?
No. As long as it isn't PDI or Invisiglass, Windex is fine.
Quoted from sturner:Is Sparkle fine for PDI?
Yes. I use Sparkle all the time on both PDI and Invisiglass. Works like a charm!
This page was printed from https://pinside.com/pinball/forum/topic/dont-use-windex-on-plastics and we tried optimising it for printing. Some page elements may have been deliberately hidden.
