Quoted from Danzig:any help?
Only coil it looks to reach would be the ball trough VUK. Seems all the thick blue wires run together.
Quoted from LTG:Only coil it looks to reach would be the ball trough VUK. Seems all the thick blue wires run together.
Thank you Lloyd, that fixed that problem. Now the other problem I’m having is I can’t get to 3 ball multi-ball, it’s only doing 2 ball, the trough switches are registering just fine, I lock 3 balls for multi-ball, but it only gives me 2 ball multi-ball, and yes there’s 3 balls in the game.
Quoted from Danzig:I lock 3 balls for multi-ball, but it only gives me 2 ball multi-ball, and yes there’s 3 balls in the game.
Balls magnetized ?
Can be an issue with that type of ball trough.
Quoted from Danzig:Thank you Lloyd, that fixed that problem. Now the other problem I’m having is I can’t get to 3 ball multi-ball, it’s only doing 2 ball, the trough switches are registering just fine, I lock 3 balls for multi-ball, but it only gives me 2 ball multi-ball, and yes there’s 3 balls in the game.
If the ball lock still has one, I would guess that ball lock 1 switch may need to be adjusted. Test all 3 ball lock switches in the switch test with a ball.
OK I finally gave up on trying to adjust the problematic trough switch so I installed a new one from Spooky, all switches read all the balls perfectly now, however I’m still only getting 2 ball multi-balls, and never a 3 ball multi-ball. Haven’t heard from Spooky yet as to wether Dominos is supposed to have a 3 ball multi-ball or not, but I assume it does, you can’t even start a game unless there’s three balls in the trough.
This page was printed from https://pinside.com/pinball/forum/topic/dominos-spooky-pinball-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
