(Topic ID: 223386)
Dolphin reset coil question
By mark532011
2 years ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by mark532011
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
I picked up a Chicago Coin Dolphin and it works pretty well, except it won't reset. I tracked it down to the "#9 Slide Bank Reset Relay Coil" not firing. When I manually push the relay the game resets and it starts right up. A check with the meter shows no voltage coming to it.#9 coil
Looking at the schematic, the "Slide Bank Reset Coil" should go to switch E2 on the reset motor and have a black-with-yellow wire between the coil and the switch and a white-with-black on the other side of the switch:schematic
and when I check the switch it looks good and has the right wires:switch
but the schematic shows a direct connection of the black-with-yellow wire from the switch to the coil and while the wire is there on the switch, on the coil I have a orange-with-green wire.
My question, am I looking at the schematic the right way?
On the other side of the switch from the coil, there is also the normally-open switch labeled "Slide Bank Reset RE." inline but I don't know what that is or where to check it.
#2 2 years ago
update: I am pretty sure I was looking at the wrong coil. The schematic shows it "slide bank reset coil" with black-yellow and yellow. The coil on the large bank of switches that perform all the reset functions has those wires so I think that may be the one shown on the schematic.
So now I don't know where "#9 Slide Bank Reset Relay Coil" is connected to as I can't find it on the schematic at all
#3 2 years ago
The schematic might not have the #9 designation. Try to take some good photos of the schematic and hopefully someone can help you find it.
#4 2 years ago
Update: The schematic shows that the "Slide Bank Reset Re(lay)" has white/blue on one side and yellow/red on the other. In checking #9 I can see that the wires do match for the center switch so that appears to be the "Slide Bank Reset Relay" but I still can't find the coil that triggers it - yellow on one side and orange/green on the other.
Any help would be appreciated!
I've got the schematic at: https://butlerfam.smugmug.com/PublicPics/i-4f9wk6Q/A
I've also got a video of the process at: https://butlerfam.smugmug.com/PublicPics/i-CRLHQZL/A
#5 2 years ago
Do you think this is it? If so, the relay is activated when both score reels are at the zero position, a normally open switch on the start relay closes and a score motor switch at B3 and A7.
#6 2 years ago
In terms of the most likely issue, I'd check the score reels first.
#7 2 years ago
thanks guys. I will check the reels, see if I can figure out how the chicago coin ones reset.
#8 2 years ago
Thanks to you guys, I made significant progress. The score wheels were in moderately poor shape and I think the contacts were not making secure contact
3 weeks later
#9 2 years ago
I've screwed something up and cannot find it. The Dolphin was working great, the wheels were working correctly so I moved on. I took off the pf and cleaned it up and put it all back togetherand thought I was in the home stretch. But now the 1000's reel is locked in use.
It works correctly, if I manually move all the score wheels and hit start, they all reset back to zero, stop moving and the game starts and plays just fine. However, the 1000's relay coil is locked on continuously and of course the 1000's wheel won't score.
I've checked the contacts on the score wheel a dozen times, I've checked the contacts on the player unit a dozen times, I've even pulled the reset bank and carefully checked each of them but I can't find it.
Looking at the schematic, https://butlerfam.smugmug.com/PublicPics/i-4f9wk6Q/A
its difficult to tell where the problem might be, it is resetting correctly and stopping at zero and the game starts so I don't think its the reset system, but there must be something that is not opening when the reset is done.
Does anyone have any thoughts?
Mark
#10 2 years ago
Don't leave the 1000 relay on for long or you'll burn up the coil.
Here are the circuits that activate the 1000 relay. From your description, start by unplugging the playfield to see whether the problem is there.
#11 2 years ago
Quoted from HowardR:
You are a genius!
I unplugged the playfield and verified it started up just fine. Checking each contact, I found the left outland contact bent inward. adjusting it and the game comes up just fine!
thank you
$ 2.50
Doc's Pinball Shop
$ 12.00
$ 30.40
$ 6,995.00
Operation Pinball
COINTAKER.COM
$ 22.00
$ 5,899.00
Great American Pinball
$ 89.00
$ 96.95
KAHR.US Circuits
$ 9,500.00
Little Shop Of Games
$ 9.00
Hdmike mods
$ 48.00
Apparel - Unisex
T-shirt- Grey Color Out of stock
Project Pinball Charity
$ 6,995.00
Nitro Pinball Shop
$ 57.95
PinBoss Mods
$ 95.00
pinballmod
€ 8.10
Buthamburg
Flashinstinct
$ 22.00
