That's the date code indicating when the chip was manufactured.
It's sometimes helpful for figuring out if a chip is counterfeit or not, though you generally don't have to worry too much about common 7400 series chips.
It is a "generic" 7406 hex invertor.
You need to be careful what you replace it with as there are several variants of this chip, 74LS06, 74HCT06, 74AC06 and so on. These additional letters tell us that these are chips with the same functionality BUT different electronic structure and are used in applications such as all CMOS circuits and so on.
In this case, look for a 7406 which will probably also have the manufacturers letter preceding the number such as SN7406 etc.
Thanks. Yes, the one I am getting to replace is: http://www.marcospecialties.com/pinball-parts/7406
Keep in mind, electronics components are usually cheaper through an electronics supplier.
https://www.greatplainselectronics.com/proddetail.asp?prod=7406
https://www.jameco.com/z/7406-Major-Brands-HEX-INVERTER-BUFFER-DRIVER-DIP-14_49091.html
This page was printed from https://pinside.com/pinball/forum/topic/does-the-top-number-on-these-chips and we tried optimising it for printing. Some page elements may have been deliberately hidden.
