Greetings, I came across an issue with my right that seemed to be much weaker than the left. All of the switch tests seem to check out everything works as it should its just weak. Wondering if the best idea is to just replace the coil for more power or if there is a better way to make it not as weak without replacing the coil. The coil does look as if it is the original from 30 years ago. I attached a video to demonstrate how weak the right sling is compared to the left. Thanks for any advice on this.
