I reciently picked up a Baywatch and it has since been shopped and reassembled. When I first got the machine the skill shots didn't work at all. It was then discovered that the setting in the game had the coil power set to high. I guess this has a software bug that makes the top right ball gate mess up and keep the ball from making it to the shark flipper or the coil to shoot it to the top left flipper. So the coil pulse is now set to normal.
Still after cleaning the game and having the software set correctly, the skill shot selection is still pretty iffy. The problem isn't with the ball gate timing or the shooter not getting the ball there. It seems that if you select the shark flipper or upper flipper skill shot....the ball will make it about half the time (or a little more), but the rest of the time the ball will hit the rubber on the top right right roll over guide and bounce back to the roll over lanes.
Are all Baywatch machine skill shot selections this hit or miss? Does anyone have a game that can make it past the controlled ball gate 100% of the time? I don't know if this is an issue with the wireform that it exits not being angled just right or something else. My first guess was that it may be caused by the shooter not shooting the ball as hard some times compaired to others, but even shots that look slower than other make it through sometimes. So fast or slow shots....it doesn't seem have a correlation on if it will make it or not.
Any ideas or suggestions....or is this just the way the game is?
