(Topic ID: 257950)
Does anyone else Mylar their new playfield plastics?
By JeffZee
58 days ago
  • 11 posts
  • 8 Pinsiders participating
  • Latest reply 14 days ago by ForceFlow
    #1 58 days ago
    I'm sure this is not my idea, but I don't remember where I may have first heard of it. I peel the backing off a sheet of Mylar and tape it to a table sticky side up. Then I peel the backing off each playfield plastic and stick it on the Mylar sheet. Trimming all the plastics is the tedious part. I don't Mylar any plastic that is significantly transparent. We've all seen plastics where the art was worn through from a screw head or a ball guide. The idea is that the Mylar would have to be worn through before the art could be damaged. I first tried this back in 2008 on a set of Space Station plastics. More than ten years later I see no ill effects.
    #3 58 days ago
    Usually that's my last resort when plastics are in danger of being damaged by rubbing.
    First, I usually install proctectors, if available. If not, then PETG washers.
    Also, if it's a nail that's rubbing (usually in older games to prevent balls from getting trapped), I hammer it in a bit more.
    Mylar is usually my last resort since it's doubtful the artwork would survive upon removal, especially for older plastics. But, I have used it in certain cases. It's just not generally my first choice.
    #4 58 days ago
    I've never done plastics but I do mylar brand new drop targets since there stamping usually doesn't last long with the ball hitting them.
    John
    #5 58 days ago
    Quoted from Dayhuff:
    John
    I do the same thing.
    #6 58 days ago
    I don't mylar the entire underside but I do place a 1/4" x 1/4" square of removable mylar everywhere there's a screw head underneath.
    #7 58 days ago
    I'll sometimes mylar just a corner of a sling plastic if it rests on a screw head of a post.
    Quoted from ForceFlow:
    Wish pbr still made their precut mylar squares for this
    #8 58 days ago
    Quoted from zacaj:
    I usually cut out a rough shape, stick it to the face, fold over the sides, then use a sharp xacto blade to trim off the excess on the back.
    #9 58 days ago
    I have only done it in spots where a screw or other piece of hardware has the chance to rub on the bottom of a piece of the plastic. I only use the "fake", easy to remove, mylar and only did it in the area where the rubbing was.
    1 month later
    #10 15 days ago
    Hmm. Have a brand new Hobbit, with plenty of targets. Should I mylar those up?
    #11 14 days ago
    Quoted from wesman:
    Couldn't hurt.
    $ 40.99
    Lee's Parts
    Cabinet - (Alt) Translites
    Maple Street Sign Shop
    $ 1,099.00
    $ 65.00
    G-Money Mods
    $ 75.00
    The Pinball Vault
    $ 29.95
    Pinball Photos
    $ 999.00
    Filament Printing
    $ 265.00
    $ 79.00
    $ 26.00
    The MOD Couple
    $ 209.99
    £ 20.00
    $ 29.99
    $ 100.00
    Professor Pinball
    $ 95.00
    M&M Mods
    $ 6.00
    Siegecraft Electronics
    $ 12.99
    Bent Mods
