I was wondering if anybody swapped different playfields in the same era cabinet. For example, using a complete EBD playfield and running it in a Fathom cabinet, and storing the Fathom PF until you wanted to play fathom again.
You could either swap -35 mpu's (or roms) or, use an Altek or Weebly and change the DIP switches. Then you could either swap S&T boards, or swap roms in the S&T as well. as the mpu if you did not have a Altek or Weebly.
I wasn't sure if anybody tried this yet. Seems like a workable idea to play multiple tables in the same cabinet for someone with limited space. I realize this is wonky in that you are losing the artistic feel of the cabinet, but you could also swap back glasses...
just a goofy idea I thought of and wondered if anybody has done it.
Thanks, mk
