I have a Fleet pinball I bought and I have cleaned it up and adjusted it as well mechanically as I can. I'm still having the problem that when the cannons fire they sometimes fire really hard and others times barely fire. I'm beginning to suspect this is because of the line voltage fluctuating.
My coil is wired directly into what looks like a lamp cord that you plug into the wall. There is a splice on the wires that leads to a small box in the coin door with a two caps, a small board with a light and other components on it. I am guessing this box is only to light the bulb and show the machine is on, but I've tried the game with and without it and it doesn't seem to matter. I also removed the small spring in the picture and it didn't seem to matter either.
Should there be a transformer in the fleet to normalize the voltage? And if there is, what voltage is this coil at and what might be a suitable transformer?
I haven't been able to find a schematic or really much info on it other then the original flyer.
