(Topic ID: 54882)
Documenting the undocumented - how would you do it?
By s1500
10 years ago
    #1 10 years ago
    If you wanted to write a manual for a machine you can't get any documentation for, what would you put in it?
    The only thing I can think of is a switch map. That, and it's hot out.
    #2 10 years ago
    If you were the government you would just grant it amnesty and then you wouldn't need documentation.
    #3 10 years ago
    A computer document file I guess.
    #4 10 years ago
    Adjustments would be good.
    #5 10 years ago
    switch map
    lamp map
    solenoid map and their drivers
    and if it's a special type of boardset no one knows about then even more
    how selftests and adjustments work
    even architecture what pcbs do what
    #6 10 years ago
    I'd follow a simple manual like a SS Bally.
    If you know of standard parts that can work as replacements, that would be a good reference too.
    #7 10 years ago
    Quoted from vid1900:
    Exactly
    #8 10 years ago
    I would make schematics for each PCB, and tables for solenoids / lamps / flashers / switchmatrix.
    On top of that also a theory of operation for each important part.
    Perhaps adjustments if the values are not self-explaining.
    The rest you find in a normal manual is ballast which I personally don read.
    This page was printed from https://pinside.com/pinball/forum/topic/documenting-the-undocumented-how-would-you-do-it and we tried optimising it for printing. Some page elements may have been deliberately hidden.
