replaced all the rubber, I've been using titan
I replaced the ballast. still didn't work. Replaced the starter, works now! $4 part at ace hardware. Easier to replace than a fuse.
Quoted from bernieberg:
- fix sparky's foot (was broke when I got it, a few attempts to fix have not been successful)
I was thinking of putting a bracket underneath, but there isn't enough room. So, I just went crazy with the JB Weld. Its a little sloppy, but you can't really see it installed. It has been holding up well so far, we shall see how it fares when it goes back on location. If it breaks again I will try
dmieczko suggestion.
2021-12-25 21_54_14-Photo in Metallica Upgrade - Google Photos (resized).png
I didn't fix the grave marker. I would like to order a new one at some point.
- ordered replacement cliffys for the mystery scoop (the one that was there broke at some point)
- maybe replace the sparky magnet again and clean up the area around it
Put in a new cliffy for the scoop. I have some mixed feelings about this. It protects to scoop, but dang, that is a hard enough shot to hit as it is.
This is the real story of this entire post. So, if you look at my before picture of the magnet, there was some mylar around the magnet.
2021-12-25 22_07_50-Photo in Metallica Upgrade - Google Photos (resized).png
When I first got the machine the magnet was mushroomed very bad, and had dug into the playfield. I replaced the magnet, but not the mylar. I now wanted to pull up the mylar and put in the cliffy carbon fiber protector. When I pulled up the mylar it pulled some of the playfield up. Bad news.
2021-12-25 22_08_57-Photo in Metallica Upgrade - Google Photos (resized).png
I believe that the playfield has been in the shape for a long time, and that the mylar was just holding it together. The damage was more than the cliffy could cover. So, I cut some black vinyl to cover the damage, put the cliffy over that (to help make it look more finished), and finally covered the entire area in some clear mylar.
2021-12-25 22_12_02-Photo in Metallica Upgrade - Google Photos (resized).png
2021-12-25 22_12_47-Photo in Metallica Upgrade - Google Photos (resized).png
I think it turned out really well, especially considering the damage that was there.
I replaced the magnet as well. Just over a years of use and it was mushrooming again.
2021-12-25 22_16_07-Photo in Metallica Upgrade - Google Photos (resized).png
color dmd looks great.
I added the snake mod. But I'm not sure I like it. You can no longer see the roll overs lights at the top of the playfield.
mirror blades looks great and I think help brighten the playfield a bit.
Shaker is fun. But not used as extensively as other games I have played.
- maybe upgrade the speakers?[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
I did not upgrade the speakers.
I'll be putting it back out on location this week.
All of the upgrades probably were not necessary for a location game, but I figured it had earned it! And hopefully the players on location will continue to have fun with it.
