Posting this in case others experience this issue:
Just picked up an extremely nice Dr. Who, seller let me play test it and everything, no complaints. Except after a while I realized the daleks weren't there on the 3rd level of the Time Expander. Everything worked since they don't affect operation of the game, I just forgot they should be there for visual effect. Were they missing?
Nope... turns out they were there, but the spring-bar that resets their position was not being triggered when the T-E moved. Here's why:
The round bar coming out of the 3rd / Dalek level, operates a spring that releases the targets when they've been flipped up. The round bar is pressed in when it rubs against the main playfield as the T-E moves. You can see the divot worn into the main pf from this.
In addition, if you look carefully, you'll notice that the bar's "resting" position is even with the edge of the T-E's mini playfield itself. So even though it works manually, it seems like it could never engage with the main pf in the first place. Maybe something was misaligned by a previous owner?
Unfortunately, that round bar is very stout and cannot be adjusted, or bent easily (if at all?) without dismantling the entire T-E. Ugh. Must be an easier way to close the gap...
There is...:
I made a bracket out of scrap 1/32" steel from an old PC power supply casing. The hole was pre-drilled, so I used tin snips to cut the sheet to shape, and then bent it as shown.
There's enough room between existing pf mounting hardware to attach the new bracket. The extended portion of the flap points forward so that it fully engages Dalek reset. Because other hardware would get in the way, the flap needs to point down so that the T-E's top level does not snag on the bracket.
And that's it. It's easy to adjust or bend the bracket to fit various wear and T-E adjustment clearances if need be, but the bracket is sturdy enough that the softer spring pressure should yield without deforming it. At any rate, I'm now greeted by Daleks when the third level rises... so I can EXTERMINATE them properly!
