This MkII kit is an upgrade of the first kit that's been under testing, I recommend reading about the first kit if you're not familiar with it:
https://pinside.com/pinball/forum/topic/modified-doctor-who-mpf-elevator-2nd-mod
This thread is the Interest / Waiting List!
It's been more than four years since I started this so please have patient with production, I'll make these kits when I find the time so waiting time may vary and be long!
I'll get in contact when it's your turn and I don't want to take pre orders or money in advance, it's fine to refrain from buying this kit or if you wish to make some changes when the turn comes to you, unanswered pm more than 30 days old will be considered as a canceled interest.
PayPal payment in sek before shipping after the kit is finished, with currency rate at the time.
A 20$ donation will be generated to Pinside for each sale.
This kit replaces the inner bracket, all five metal rollers, their washers and the upper brace.
In order to install this kit you need the outer bracket with optos, a fully functional motor and gearbox with its bracket, these parts should be intact without any major damage.
Three holes in the bottom of the Outer Bracket has to be drilled to install the Bottom Reinforcement.
Updates made from the first kit:
* Thicker shafts which can be used with three different types of bearings on the Upper Linear Shaft Bearing Units:
#1 IGUS Type Bearing of Solid Polymer RJMP-01-06, these bearings was what I initially planned to use but they were not available for the thinner shafts on the MkI Kit, these are what I recommend and is installed as standard!
#2 Linear Ball Bearing LM6UU, used on the MkI Kit, still working fine in the MkI Beta kits.
#3 Self Lubricating Graphite Brass Bearings JDB LM6UU LM6, not tested and more expensive, these will be sold separately as an option but I don't consider them to be suitable for this application.
* Some parts is now being FDM Printed PETG.
* New design for the Upper Linear Shaft Bearing Unit for the Larger Bearings.
* New design for the Lower Linear Shaft Attachment for the Thicker Shafts with damping and more material for the shaft attachments.
* Bracket Chims of PETG for leveling the Mini Playfield against the Playfield included.
* Modified Cam is included in the kit.
* Brass Connecting Hex Rod instead of Aluminium.
* Some measurement changes.
The parts thats now being replaced by 3D printed MJF PA12 GB and FDM PETG is in bottom and on the sides of the bracket since these parts mainly acts as guiding and are not under much force or pressure:
# The Upper Linear Shaft Bearing Unit PA12 GB.
# The Outer Linear Rail Attachment PETG, Aluminium is used in the Premium kit.
# The Outer Bracket Bottom Reinforcement PETG, Aluminium is used in the Premium kit.
Available colors for the Outer Linear Rail Attachment and the Bottom Reinforcement made of PETG:
# Jet Black RAL 9005
# Sapphire Blue RAL 5003
Upper Linear Shaft attachment of PA12 GB is made in Gray only.
Parts attached to the Mini Playfield is still made from aluminium, the kit have not yet been confirmed to fit with the cpr repro mini playfield.
Two Versions of the Kit is available, STANDARD & PREMIUM
STANDARD LIFTER KIT:
3800sek + shipping cost, Postnord prices 230721; USA, Canada, UK, Norway & Australia 224 sek, Europe 292 sek, Sweden 118 sek.
LIFTER KIT PARTS:
1. Pre-assembled and Loctited connecting rod and center MPF attachment.
2. Pre-assembled linear rail units for Left and Right side, MGN12C-150 Linear Guide Rail with RJMP-01-06 Bearings. Lower Shaft Attachment of Aluminum, Upper Linear Shaft attachment of PA12 GB.
3. Outer Linear Rail Attachment of PETG in Jet Black or Sapphire Blue.
4. Bottom Bracket Reinforcement of PETG in Jet Black or Sapphire Blue.
5. Brace with fixed c-c (center to center) distance.
6. Drill Templates for Outer Bracket and Gearbox Bracket (colors vary).
7. Opto Cover of PETG in Jet Black.
Thanks to dahlman at Degerforce Pinball for development of the Modified Cam.
This Cam has correct height for the elevator in both middle positions.
Note that this Cam has a Round hole and is missing the D arbor hole, it has two sturdy set screws instead and is made of thicker sheet metal.
Powder coated fine textured matte, Black or Sapphire Blue.
PREMIUM LIFTER KIT:
4500sek + shipping cost, Postnord prices 230721; USA, Canada, UK, Norway & Australia 224 sek, Europe 292 sek, Sweden 118 sek.
Includes bottom bracket reinforcement and L + R outer linear rail attachment engraved logo with or without a TAG of your choice, raw or powder coated aluminium.
Add 100sek if you would like to have a set of PETG parts included in the Premium Kit.
OPTIONS:
B/W Printed paper copy of the latest manual, add 50sek (Downloadable PDF is free of charge)
The new improved motor controller board by pellew can be shipped together with the kit at no extra shipping cost.
https://pinside.com/pinball/forum/topic/improved-motor-driver-a-15680-for-doctor-who
There are No Guarantees with this kit, All work, installation or operation with the elevator is at your own risk and responsibility!
I'll do my best to support you though.
This is mainly functional parts, visible imperfections will occur on some surfaces!
This kit will not solve any problems if you're using a bad gearbox with Stripped Gears or a Wobbling Main Shaft.
Any additional extra costs like customs, taxes or PayPal fees is not included, shipping prices may vary.
A package which has not been picked up and been returned will only be half refunded.
Verified Pinside accounts only.
Put your interest in this thread or send me a pm If you're fine with these conditions.
